how-to: Log AFR from the LC-1 w/o a serial cable
Old Jun 22, 2011 | 12:30 PM
  #421
mclaren's Avatar
Originally Posted by krazykorean84
Take a look at your zeitronix ZT2 manual at the section describing what all of the wires are. Depending on what version you have:
- Older version: The purple wire is the digital signal and the white wire is the analog signal.
- Newer version: The white wire is the digital signal.
This is of course if my memory serves me right. Check your manual/instructions though.
If using the digital signal then everything is much easier and you should be able to set it up using Mr. Fred's instructions (Disregard the grounding portion of the instructions with the digital signal, your ZT2 should already be grounded). Good luck and if there are any questions, ask.
Thanks
Old Jun 23, 2011 | 11:57 AM
  #422
killerpenguin21's Avatar
ok so im stuck.
based on having put in a brand new sensor, and upgrading the firmware on my lc1, i think i have narrowed my problem down to an evoscan issue.
i have the lc1 wired directly to the ecu since i have a mac with no serial port. I hooked up logworks using a friends laptop and the car idles at ~15.5 when fully warm.
on evoscan (im using 2.7) fully warm idle reads 7.35 steady for a bit then will swing to the 9's sometimes.
during cruise, the values look somewhat appropriate and the readings are very responsive.
when doing a 3rd gear pull there is no "tip in", it just jumps to a value in the 10's and holds and (i know my tune is very rich, but the readings dont seem to correlate with cells being hit in the map)
basically i cant trust this to do any tuning.
below are a map trace and clip from virtuyal dyno. what the heck could be causing this?
Old Jun 24, 2011 | 10:35 AM
  #423
No ideas?
Old Jul 4, 2011 | 12:11 PM
  #424
prowakeskater's Avatar
anyone get this working with a 94170015 rom?
directions on how to do it?
Old Jul 4, 2011 | 01:17 PM
  #425
I have set my mut12 address to 8409 (using 0x8409 of course), but my readings are at a static 12.8
help?
Old Jul 4, 2011 | 01:27 PM
  #426
ok ok, I see what I missed. I havent set the RAM address for the ADC input
again, I have a 94170015 rom
i know that with other roms, this code can be used:
<table name="Rear O2 (ADC 0A) RAM variable" category="Rear_02" address="c2be" type="1D" level="1" scaling="Hex16"/>
This is not the code for my rom though, so will c2be need to be different? I would assume so!
Once I get this correct, I know I can then go into ecuflash and open the 1d table and change it to 8408
Please help finding this correct address!
Old Jul 5, 2011 | 08:24 PM
  #427
edit:
found the mut address the ECU reads for the rear 02 sensor/wideband
its 3C
So for evo 8 owners, if you want to do this EASILY, do the mod to remove the CEL, and thats it. Dont modify anything else, and just read from 3C and you will be home free
Old Jul 21, 2011 | 01:26 PM
  #428
3vo|3oost's Avatar
Im still learning and any help would be greatly appreciated... I just wired in my wideband data-output wire to the rear O2 sensor in my ecu and it reads fine from 0-5V in the excel chart... but what formula do I change to make it show up as an A/F ratio? I have the Openport 2.0 and using the microSD card to log standalone... but im confused as how to have it show up as a A/F ratio number in the excel chart. Thanks in advance for the help guys!!!
Old Aug 3, 2011 | 05:00 AM
  #429
audiofan's Avatar
The formula is: (Volts * 2) + 10 = AFR
Old Aug 3, 2011 | 03:35 PM
  #430
mclaren's Avatar
Can someone explain this to me. When I read the x=value from the ECU on my 88590015 ROM. It does not read out in 0-5V but rather #0-255. 14.7:1 on the digital readout on my zt-2 reads out as like 128 in evoscan. How can I get the thing just to readout in 0-5V? That way I can just use the Zeitronix Formula. Thanks
Old Aug 4, 2011 | 06:04 AM
  #431
3vo|3oost's Avatar
My formula in evoscan under the tephra v7 mod ROM, shows up as "WBO2" 10.00+(16.99-10.00)*x/255... for the 3C MUT ID and for some reason at idle it is logging around 13.3-13.5 but I know its supposed to be around 14.7. I have a glowshift wideband gauge that reads from 20-10 a/f so would I have to change my formula to 19.99-10.00 instead of 16.99-10.00? Or do I need to change the scale of my load of 255 to 350 since I have the big maps conversion? Just a little bit confused with all the formulas here, Thanks
Old Oct 20, 2011 | 12:43 PM
  #432
TunerHead24's Avatar
Originally Posted by mrfred
I'm currently spanning from 9:1 to 17:1 using the analog out. The formula I'm using is:
0.03137*x+9.05
So I added an offset of 0.05 AFR. I could add another 0.05 AFR offset.
this formula goes in the eval for evoscan right? i just want to make sure...
Old Oct 21, 2011 | 04:10 AM
  #433
audiofan's Avatar
I've been trying different things to get the correct one
The formulas in evoscan, the correct one (in theory) should be: 0,03921*x+10, since it displays values from 10 to 20, and should be correct with the table relating volts to AFR, but after some logging and comparing what evoscan was displaying and the gauge itself, they were a little off (1 to 1,5 afr points difference)
Now I'm using the formula: 0,05859*x+7,7, when in boost at WOT, seems to be the same between the evoscan screen and the gauge (kind of hard to look at both at the same time and compare). when I lift off it goes lean to 22+ which the gauge shouldn't read, and when the tune was really rich it showed 9,8 which is also out of the parameters. But WOT, idle and cruising, I like it better than the previous formula, is much closer or almost the same as what the gauge itself displays.
Old Oct 31, 2011 | 03:39 PM
  #434
wow! 0,05859*x+7,7 is dead on! works perfect, thank you sir
Old Oct 31, 2011 | 05:20 PM
  #435
audiofan's Avatar
Glad it works!
