how-to: Log AFR from the LC-1 w/o a serial cable
Old Aug 10, 2019 | 03:23 PM
  #511
Evo8Emperor's Avatar
So would anyone be around to help me figure out a formula for my prosport wideband. It uses the bosch lsu sensor. I just double checked my work with biggiesacks method of checking it reads voltage with logging the request id 3c and using the formula 0.01952*x.
I did see a voltage of 2.6 to 2.7 which had the gauge in the 15 area which is correct. Just need to figure out what i did wrong in the equation.
the wideband reads from 10-20
i used the original formula and replaced the values with mine.
(17.0-9.0)/255*x + 9.0 = 0.03137*x + 9.0 <-------------Mr Freds and what i tried ----------------> (20.0-10.0)/255*x + 9.0 = 0.03137*x + 9.0
(20.0-10.0)/255*x + 10.0 = 0.03137*x + 10.0
Tried both ways seeing i wasnt really sure as to what values were meant to be changed and what stayed. Didnt see any difference in either way though. Just showed a zero or 1 i believe the whole time.
Old Aug 10, 2019 | 03:53 PM
  #512
Well guess i posted too soon. I went back and used Tephra's formula and inputed my values and it was spot on.
Old Apr 30, 2020 | 04:47 AM
  #513
mindfreakattack's Avatar
Can anyone share what is the best way to connect the analog singal wire from my wideband to the oem evo 9 ecu? I'm targeting the ecu slot 93 for my wideband signal. any help would be very much appreciated.
Old May 1, 2020 | 10:16 AM
  #514
Evo9isLife's Avatar
5 Year Member
You would connect it to pin 73 on the ecu, but there are changes in the rom you must make. See post #1 of this thread.
tephra
Apr 22, 2026 11:03 AM
tephra
Dec 26, 2023 01:11 PM
mrfred
Sep 14, 2022 07:08 PM
xPRimNT
157
Dec 26, 2018 08:09 AM
Jack_of_Trades
May 29, 2018 07:05 AM
