Looking for more maps, 80700010 Def
Old Nov 19, 2008 | 10:03 PM
  #241
Mattjin's Avatar
Today I did some more Octane Control work and found a few more maps that go with it. The Octane Control can be effectively disabled by just raising the Engine Temp to a value that is never reached. The 2D maps are rate of change maps, where the lower the number the faster the octane will change. Setting it to 255 turns it off at that particular Engine Load amount. As a small note, I saw someone else had mentioned these maps recently for another rom, but it didn't click until today that they were referring to the same maps that I was working on for a while now. So whoever it was, partial credit goes to them too :-)
<table name="Octane Control Enable Engine Temp" category="Timing" address="17a4" type="1D" level="2" scaling="Temp"/>
EDIT - These maps were removed because they were incorrect. Close, but not correct. JCSBANKS has a thread with the correct maps. The above 1D is correct though.
Old May 18, 2009 | 05:54 AM
  #242
AusTuner's Avatar
I have just read all of your thread, You have done a lot of work.
Have you you posted your final .xml
I just tuned a customers GTA today, but the def file was one that had none of these extra maps you have found. Where can I get a copy of your .xml?
Again great work!
Old Aug 7, 2010 | 06:07 AM
  #243
evonut270's Avatar
does anyone have the proper scalings+addresses for the shift pressures etc on 80700010?
Old Aug 7, 2010 | 03:44 PM
  #244
merlin.oz's Avatar
I know Matt was looking at the pressure stuff, but it was hell complex and he may have given up on it.
Old Aug 7, 2010 | 08:33 PM
  #245
GregM's Avatar
Try this:
http://translate.google.co.nz/transl...DN%26prmd%3Ddf
They define upshift pressure and time, but not downshift.
I can confirm that these work in a 89970010 rom, but it states its for the 80700010 rom as well.
Old Oct 24, 2010 | 09:55 PM
  #246
merlin.oz's Avatar
bumping this thread as i am going to have a look at the shift pressure settings.
Old Feb 25, 2011 | 07:56 PM
  #247
loosecannon's Avatar
hi all , i was reading through the posting ... great job of finding the maps thanks guys ... i got a GTA wagon , i hope you help with my maps definition . thanks .
Old Feb 26, 2011 | 01:01 PM
  #248
foxbat's Avatar
This thread should have resulted in a comprehensive definition file for the 80700010, but Mattjin abruptly stopped posting late 08 without publishing such file! My main issue with the 80700010 for now is that I'm unable to remove the boost (fuel) cut which occurs at 19psi (1.3bar) because of falsely defined boost limit table. Although Mattjin did post 2 addresses for two boost limit tables, but still I think that rpm columns addresses are needed too, in order to define the two boost limit tables in the XML.
Old Feb 26, 2011 | 02:27 PM
  #249
nads1978's Avatar
I too had a problem with boost limit tables -recently infact (2 weeks ago), so much that I had to resort to ECUtek.
I Emailed Mattjin & couldn't give me the def file. I understand his reasons though, he spent hundreds/thousands of hours researching/decompiling the GTA ECU. He uses the information gained to do other Mitsubishi ECUs too - this forms a core part of his business & therefore he doesn't want to give away his hard work.
Annoying, but understandable!
Old Feb 26, 2011 | 02:48 PM
  #250
foxbat's Avatar
Hey Nads,
I have the addresses for the two boost limit tables, do you think that's enough information to add them to the XML?
I even tried to insert a big number under 'boost cut delay timer' but to no avail!
I think there is a piece of hardware called 'fuel cut defencer' by HKS that should be able to remove boost limits, I might try that as a last resort.
About Mattjin, what is his business, web site?
Old Feb 26, 2011 | 06:30 PM
  #251
tephra's Avatar
I just looked this up for you guys, unlike other CT9A's there are two tables:
Code:
<table name="Boost Limit #1" category="Turbo" address="3a48" type="2D" scaling="LoadBoost">
	<table name="RPM" address="6266" type="Y Axis" elements="9" scaling="RPM"/>
</table>
<table name="Boost Limit #2" category="Turbo" address="3a58" type="2D" scaling="LoadBoost">
</table>
Old Feb 26, 2011 | 06:33 PM
  #252
Benja's Avatar
Dave, does the GTA run a two-stage system like the manuals do?
Is the second boost cut set up for a lower part of the rpm/mph cross-over as a style of torque limiter in lower gears?
Old Feb 26, 2011 | 06:36 PM
  #253
tephra's Avatar
no only a single solenoid setup.
i dont think its a crossover function..
my definition file isn't good enough to just "see" what its going - unfortunately..
Old Feb 27, 2011 | 01:52 AM
  #254
nads1978's Avatar
Originally Posted by foxbat
Hey Nads,
Sorry I don't know enough about it mate, I'm just a user!
PM coming over ref mattjin's business.
Old Feb 27, 2011 | 01:56 AM
  #255
nads1978's Avatar
Code:
</table>
</table>
If anyone has a recent def file with this ^ in, please link to it!
