Looking for more maps, 80700010 Def
Old Jun 28, 2011 | 02:41 AM
  #271
GregM's Avatar
Originally Posted by wreckleford
Does anyone know the 2-byte load address for 88970017 (2005 Airtrek)? I am willing to donate some money if someone is willing to take the time to find it. Thanks.
Not sure if 89970010 is the same or not, but mine are:
change in cell 0, 0 from 696B to 6A36 and change 0,1 from 696A to 6A37
Old Jul 1, 2011 | 07:44 PM
  #272
foxbat's Avatar
How about 2-byte or even 1-byte load addresses for the 80700010 has anybody found those?
Old Jul 3, 2011 | 07:01 AM
  #273
wreckleford's Avatar
Thanks, I will try it out and let you know.
Old Jul 3, 2011 | 08:41 AM
  #274
Also, has anyone found the stationary thermo fan duty for any of the airtreks. I have the 9 column map already, but not the 3 column one that works while the vehicle is stationary.
And, has anyone found the second boost limit map for any of the Airtreks?
Old Jul 3, 2011 | 09:35 AM
  #275
nads1978's Avatar
................for any of the Airtreks?
Do you have any ECU Pin-outs for the Auto Airtreks?
Old Jul 3, 2011 | 11:14 AM
  #276
GregM's Avatar
Suppose to be the same as GTA.
Old Jul 3, 2011 | 11:15 AM
  #277
GregM's Avatar
This one??
<table name="Thermo Fan Duty - Stationary" category="Misc" address="5412" type="3D" level="2" swapxy="true" scaling="uint8">
<table name="Conditions" type="Static X Axis" elements="3">
<data>On</data>
<data>Off</data>
<data>On A/C</data>
</table>
<table name="Engine Temp" address="6040" type="Y Axis" elements="12" scaling="Temp"/>
</table>
Old Jul 3, 2011 | 12:25 PM
  #278
GregM's Avatar
Boost Limits
<table name="Boost Limit N,1,2 Gear" category="Turbo" address="37fe" type="2D" level="4" scaling="LoadBoost">
<table name="Engine Speed" address="684c" type="Y Axis" elements="9" scaling="RPM"/>
</table>
<table name="Boost Limit 3,4,5 Gear" category="Turbo" address="380e" type="2D" level="4" scaling="LoadBoost">
</table>
<table name="Boost Limit" category="Turbo" address="381e" type="2D" scaling="LoadBoost">
<table name="RPM" address="684c" type="Y Axis" elements="9" scaling="RPM"/>
</table>
Old Jul 3, 2011 | 12:53 PM
  #279
nads1978's Avatar
Hence my query!
Old Jul 3, 2011 | 01:10 PM
  #280
GregM's Avatar
Hence my query!
I've used the GTA pinout for doing some wiring on my ecu, what I saw matched. Never went through each pin to confirm 100%, just the ones I needed.
Old Jul 3, 2011 | 01:29 PM
  #281
nads1978's Avatar
Where did you get the GTA pin-out? Is it the one I made/researched in my signature, or have you another version?
Old Jul 3, 2011 | 01:36 PM
  #282
GregM's Avatar
I'll check tonight when I'm home, but I'd guess its your one. I think I got it from Lancer Register ages ago. Is there anything in particular you want checked?
Old Jul 3, 2011 | 01:39 PM
  #283
nads1978's Avatar
Nah, just looking for any official or unofficial pin-outs from cars with similar/same ECUs, to help confirm my findings. I also need a few more to finish off what I need; I'm trying to swap my ECU for a Evo 8 FQ300 ECU, which is wired completely differently. (I no longer have the auto box)
Old Jul 3, 2011 | 01:45 PM
  #284
GregM's Avatar
I have the same ecu sitting here. I saw it for sale cheap and grabbed it as I understand its the only 3 plug evo ecu which doesn't have Mivec, so can run our engine. I thought if I ever went manual I'd swap to it, but I've now got a pretty decently defined xml for my rom, so probably not much point.
Old Jul 3, 2011 | 01:48 PM
  #285
nads1978's Avatar
Plus, can get some Tephra mods
Want to share your xml? Mine is in my signature.
