cold start enrichment table
Old Dec 13, 2008 | 06:54 AM
  #151
gear head's Avatar
Originally Posted by mrfred
I think gear head has has got it in his evo 8 xmls that he made up for me:
https://www.evolutionm.net/forums/ec...ml#post6431228
They are there for the 96940011. I didn't have the correct addresses for the 96530006.
Old Dec 16, 2008 | 11:48 AM
  #152
Creamo3's Avatar
So I've read through the thread a couple times and have found the new tables helpful; what I've noticed:
- On my injectors (FIC 1150's), I had a hard time getting them to start on stock Crank Enrich & Post Enrich settings. I wound up increasing the crank enrich & Post Enrich by a good bit in the positive temp region and that has helped tremendously. I'm still having a weak hot start and will continue to tweak to see if that can improve.
Would increasing injector latency at lower voltages help at all w/ cold start?
Old Dec 17, 2008 | 12:32 PM
  #153
EV0lut10n_8's Avatar
I had to play with these values last night to get my car started. Only thing was my car ran rich the entire way home.
According to what everyone is saying these values only affect below 500rpms. Seems to not be the case.
Old Dec 17, 2008 | 12:40 PM
  #154
l2r99gst's Avatar
Are you on pump gas or E-85?
The only reason I ask is because I noticed you live by me in Chicago and during the coldest days here in the winter my car seems to have touble starting and I'm just on normal pump gas.
With all of these new found cold start fueling and ignition tables, I was thinking about tweaking them some to see if I can get my cold starts a little better.
Old Dec 17, 2008 | 12:41 PM
  #155
I am on pump. I actually couldn't start my car at all for the past two days. It had been stuck at work. Late last night after reading this thread I gave it a shot. Had to add 50 pts of enrichment from stock. It finally started up and I drove home. But was running rich the whole way.
Old Dec 17, 2008 | 12:51 PM
  #156
l2r99gst's Avatar
That's interesting. My car tends to start having a little bit of an issue when it gets below about 15*F. One time it didn't want to start at all, but this was sitting overnight during the coldest night a couple years ago...I think the temps were like -20 (and that's air temps, that really cold week we had).
It wasn't a battery issue either, since I am running that same battery now, years later. My car just wouldn't 'catch', so to speak. The starter would just keep turning and turning and the car would just about want to catch, but just never would. I finally held the key for like 30 seconds, while pumping the gas a million different ways and basically rode the starter until it caught and it just barely hung on struggling.
I think it has to do with the settings in some of these new tables. Since it has been cold here lately, I have been trying to monitor things a little closer and I notice the colder it is, the richer my car runs right after being started. The wideband O2 will take 30 seconds or so to warm up and the wideband even at that time is reading like 10.9-11.0. After a minute or so, it slowly works back to a stoich 14.7 and the engine tone sounds cleaner. Before the wideband warms up, I can tell the car is running even richer and 'struggling' a bit. It seems like the colder it is, the richer is runs.
But, based on your explanation, the richer setting helped the car start. Whereas in my situation, it seems like the car is struggling because it is too rich. Since I never had a no start issue since that cold night, I never really looked into it, but with these new findings, I'm curious to try some things out.
Has anyone else noticed tougher times starting during colder weather, with it not being battery related or normal cold temp issues?
Old Dec 17, 2008 | 12:52 PM
  #157
logic's Avatar
If you guys are having trouble with cold start on pump here in Chicago, I'll stop whining about it taking two or three tries to get my car to start on E-85.
Old Dec 17, 2008 | 12:56 PM
  #158
l2r99gst's Avatar
Haha, yeah that's one of the reasons why I haven't switched to E-85 yet...I was worried about the cold start issues. Seems like most people have that worked out with these new tables, though.
I also wanted to make sure I didn't have something wrong with my car either, since I did have that starting problem that one cold night. I never had a problem since, even in subzero temps, but I notice it a bit harder to start the colder it gets and running rougher right after startup the colder it gets.
Old Dec 17, 2008 | 01:03 PM
  #159
RazorLab's Avatar
Log your IPW and you will see it is the case, only adds fuel on cranking. Richness quickly after is residual.
Your injector scaling and latency might be off, when its really cold it will take longer for you car to warm up and go into closed loop where fuel trims take effect.
Old Dec 17, 2008 | 01:16 PM
  #160
don't get me wrong, this is my first time ever using ecuflash and trying to program anything in my car, so it definitely maybe operator error/noobness. I just know i need to play around with it more.
I get that the first crank tables are for the first crank and post primer are for right after, now the % decay is that saying that every crank there after will decay the pulse width by that percentage?
Old Dec 17, 2008 | 02:23 PM
  #161
mrfred's Avatar
The units for the post primer and decay aren't well defined yet, so if you tweaked those values, then the car may well have run rich at first, but closed loop feedback should have sent the AFRs back to 14.7:1 as soon as closed loop kicked in.
Old Dec 17, 2008 | 02:30 PM
  #162
my min coolant temp for closed loop is default at 7 degrees C. That would have been hit easily on my way home. But the car was chilling at 11-12 ish when i got home and idled in my garage. Maybe my wideband needs recalibration.
Old Dec 17, 2008 | 03:13 PM
  #163
mrfred's Avatar
You're fuel trims will tell you the story. If the car really is running rich in closed loop, then the trims will be full negative (-25% if you are using the correct scaling), and the car should throw a CEL pretty soon.
Old Dec 17, 2008 | 03:16 PM
  #164
l2r99gst's Avatar
mrfred,
I just re-read this entire thread, since it has been a while since you originally posted these maps and I found them for my ROM.
Reading through this again, I noticed several people posted decay maps and running maps and I noticed that you stated that you hadn't found the running maps for your ROM yet.
Have you looked at the 8 or so maps that start at 3126? There are about 8 or so at 3126, 3136, 3146, etc.
These same maps for 96940011 appear to start at 2dea.
Based on the threads from mattjin and others, it seems as if the first two are decay maps, then the next two are post running maps?
Eric
Old Dec 17, 2008 | 03:21 PM
  #165
Creamo3's Avatar
It must be a Chicago thing because I've been trying to get the car to fire up and it still takes a few cranks when the engine is cold. When the engine is hot it will turn over but not with authority. Playing w/ the enrich tables has helped a little, but still not to where I want it.
