cold start enrichment table
Old Jan 22, 2009 | 01:09 PM
  #196
mrfred's Avatar
Originally Posted by travman
This might be a stupid question - but where is this table? I have looked through my rom defs. and I do not have it? (I am updated with the latest/greatest you posted for 88590015)
I guess I haven't included it. I can do that soon.
Originally Posted by fixem2
MrFred, I will try that. I think I have the switch low to accomodate MPG cruising. I there a way to have both?
Travman, still paying 1.49/gallon here for E85 and 93 is over 2.19.
Are you using my closed loop wideband patch?
Old Jan 22, 2009 | 01:31 PM
  #197
fixem2's Avatar
No I have not switched my LC1 to feed the ECU. Still using the stock NB sensors. I have the open loop tables changed for cruise MPG so I can run 15.5 AFR while cruising. I bet I am confused and not thinking of the right tables, correct?
Old Jan 22, 2009 | 01:50 PM
  #198
fostytou's Avatar
EvoM Community Team
Just curious... what sort of multipliers were you using for your cells? I was running the 1.3 formula and didn't have any trouble until a couple of days when it was -10. It took about 30-40 seconds of on and off trying but I got it to fire and then it ran like a champ. After the second or third one of those days I decided to not be so hard on my engine/starter (and wallet with the falling pump prices) and switch back to 93 until the winter fades a bit.
I miss the power, but the LM-22 and salty roads couldn't grip together if they wanted to... alot of times even on pump.
Old Jan 22, 2009 | 01:55 PM
  #199
fixem2's Avatar
For the E85 cold start issue, I adjusted my IPW start tables per the setting MrFred posted in another thread. Starts in -15 degrees with 3-4 cranks.
Old Jan 22, 2009 | 08:18 PM
  #200
mrfred's Avatar
The open loop load and TPS tables will control when the car goes open loop as well. I believe there is also a min coolant temp for closed loop. At any rate, as you suspect, you can't have it both ways, unless you are using my closed loop wide band patch. I suppose I could write a patch to have a separate open loop AFR for a cold engine. Not sure when I'd get to that
Old Jan 22, 2009 | 08:57 PM
  #201
fixem2's Avatar
I do not have a min coolant temp for closed loop defined for the 96530006 ROM. Your closed loop WB patch allows for both settings?
Old Jan 23, 2009 | 05:42 AM
  #202
logic's Avatar
This is what I have for 96530006:
Code:
<table name="Min Coolant Temp for Closed Loop" address="15aa"/>
Old Jan 23, 2009 | 11:10 AM
  #203
mrfred's Avatar
Code:
Do you have the location for the 96940011 ROM?
Old Jan 23, 2009 | 11:39 AM
  #204
logic's Avatar
This is what I have for 96940011:
Code:
<table name="Min Coolant Temp for Closed Loop" address="11aa"/>
In both cases, caveat emptor; you might want to double check.
Old Jan 23, 2009 | 12:25 PM
  #205
mrfred's Avatar
Code:
Thanks. I just went through the subroutine where its refrenced, and the setting is indeed min coolant temp for closed loop. Its the same for USDM Evo 9, so:
<table name="Min Coolant Temp for Closed Loop" category="Fuel" address="11aa" type="1D" level="1" scaling="Temp"/>
Old Jan 26, 2009 | 12:25 AM
  #206
SuPeRNeT's Avatar
Any Word on the 96420011?
Old Jan 27, 2009 | 11:13 PM
  #207
tobz's Avatar
Good Question!
Old Feb 4, 2009 | 04:09 AM
  #208
Ads77's Avatar
Does anyone have the Startup IPW adder table for rom ids 93660005 and 96260007 ?
Hope someone can help
Old Feb 4, 2009 | 07:47 AM
  #209
C6C6CH3vo's Avatar
Originally Posted by mrfred
All 96420007/96420008 users should switch to the 96420011 ROM. Its poor use of our time to find all these tables for every ROM.
Is it easy to change to 96420011 from 0007 once patched (1.5 year old patch I want to keep)?
Old Feb 12, 2009 | 04:09 PM
  #210
mplspilot's Avatar
Has anyone discovered a running/tip-in enrichment? My car goes lean on tip-in and stumbles for a split second after a gear shift for the first couple of minutes of driving in frigid weather. It's very annoying...
It doesn't happen if i wait a couple of seconds after releasing the clutch though.. or at idle... only happens if the tip-in happens right after i press the clutch .. fwiw..
