cold start enrichment table
Old Oct 23, 2008 | 03:05 AM
  #106
Mattjin's Avatar
This is what I have.
For 90550001:
<table name="Cranking Primer (First Pulse)" category="Fuel" address="39c0" type="2D" level="3" scaling="uint8">
<table name="Engine Temp" address="511e" type="X Axis" elements="11" scaling="Temp"/>
</table>
<table name="Post Primer Enrichment" category="Fuel" address="3922" type="2D" level="3" scaling="uint8">
<table name="Engine Temp" address="5102" type="X Axis" elements="9" scaling="Temp"/>
</table>
<table name="Post Primer Enrich Decay" category="Fuel" address="3912" type="2D" level="3" scaling="EnrichmentAdj">
</table>
<table name="Post Primer Enrich Load Control" category="Fuel" address="38fe" type="2D" level="3" scaling="uint8">
<table name="Engine Load" address="4e1e" type="X Axis" elements="14" scaling="Load"/>
</table>
Old Oct 23, 2008 | 04:15 AM
  #107
BarryC's Avatar
cheers mate
Old Oct 23, 2008 | 08:21 PM
  #108
laramie_05MR's Avatar
Originally Posted by evo828
Found some compensation tables for 96530006 - most usefull seems to be the one called "IPW comp starting".
<scaling name="IPW mcsec" units="mcSec" toexpr="x*432/1000" frexpr="x/432*1000" format="%.0f" min="0" max="255" inc="1" storagetype="uint8" endian="big"/>
<scaling name="McSec" units="mcSec" toexpr="x*4" frexpr="x/4" format="%.0f" min="0" max="255" inc="1" storagetype="uint8" endian="big"/>
<table name="Start IPW latency mcsec" category="Fuel" address="1569" type="1D" level="1" scaling="McSec"/>
<table name="IPW comp starting" category="Fuel" address="3822" type="2D" level="1" scaling="IPW mcsec">
<table name="Water temp" address="69be" type="Y Axis" elements="8" scaling="Temp"/>
</table>
<table name="IPW comp warmup 1" category="Fuel" address="3712" type="2D" level="1" scaling="IPW mcsec">
<table name="Water temp" address="69d8" type="Y Axis" elements="9" scaling="Temp"/>
</table>
<table name="IPW comp warmup 2" category="Fuel" address="3722" type="2D" level="1" scaling="IPW mcsec">
</table>
<table name="IPW comp running 1" category="Fuel" address="3732" type="2D" level="1" scaling="IPW mcsec">
</table>
<table name="IPW comp running 2" category="Fuel" address="3742" type="2D" level="1" scaling="IPW mcsec">
</table>
<table name="IPW comp running 3" category="Fuel" address="3752" type="2D" level="1" scaling="IPW mcsec">
</table>
<table name="IPW comp running 4" category="Fuel" address="3762" type="2D" level="1" scaling="IPW mcsec">
</table>
<table name="IPW comp running 5" category="Fuel" address="3772" type="2D" level="1" scaling="IPW mcsec">
</table>
<table name="IPW comp running 6" category="Fuel" address="3782" type="2D" level="1" scaling="IPW mcsec">
</table>
Thanks
Old Oct 24, 2008 | 11:48 AM
  #109
evo828's Avatar
An additional for 96530006 - the most useful for cranking - I've tested if I put zeros - there was zero injection in the log during cranking (car did not start - when stock values were there - there were adequate ipw values in the logs (car started - put scaling IPW mcsec as the values in the table macth the IPW values I've seen in the log:
<table name="Cranking Primer (First Pulse)" category="Fuel" address="5b3a" type="2D" level="3" scaling="IPW mcsec">
<table name="Engine Temp" address="69f4" type="Y Axis" elements="11" scaling="Temp"/>
</table>
</table>
Old Oct 24, 2008 | 02:24 PM
  #110
logic's Avatar
Just a quick typo correction: the scaling for the Cranking Primer table should probably be "IPW mcsec", going by your previous post.
Good stuff, thanks for taking the time to track this down.
Old Oct 24, 2008 | 02:52 PM
  #111
Mattjin's Avatar
I decided to leave the numbers raw just due to the fact that you end up with messy decimal place numbers rather than just more easily considering it a control factor.
To clear up what the maps do. Cranking first pulse is the first type of enrichment when cranking begins. It then switches to what the aftermarket calls a Post Start Enrichment which is labelled here as a Post Primer Enrichment because it takes effect as soon as the cranking pulse has finished. This adds fuel to the normal mapping and it will decay (reduce over time) this enrichment based on the decay map. I am yet to thoroughly investigate the load control map but from initial testing it will reduce the effect of the post primer enrichment under heavy load to prevent running too rich (enrichment not needed at this level of airflow).
So if you car is hard to get fired up, play with the Cranking map. If it fires up and runs crappy for the first few seconds play with the Post Primer maps.
Old Oct 24, 2008 | 03:21 PM
  #112
mfr122887's Avatar
Thanks for clearing that up. Do you have the addresses for 94170015?
Old Oct 24, 2008 | 03:28 PM
  #113
PeteyTurbo's Avatar
any patches that have been tested for 96940011?? My car is taking forever to start, kinda sucks..
Old Oct 24, 2008 | 03:48 PM
  #114
mplspilot's Avatar
mmm, me wants some post primer maps for 9417 0008 or 0015
Are there any tables that are used on cold-start gas tip-in? My car always leans out to the sky for a split second on tip-in right after cold start-up... (only with depressed clutch btw)
Old Oct 24, 2008 | 04:06 PM
  #115
PeteyTurbo's Avatar
Mine is the same way, but clutch makes no diff..
Old Oct 24, 2008 | 10:20 PM
  #116
RazorLab's Avatar
<scaling name="Percent255" units="%" toexpr="100*x/255" frexpr="255*x/100" format="%.0f" min="0" max="100" inc="1" storagetype="uint8" endian="big"/>
<scaling name="TimingTrim8" units="units" toexpr="x-128" frexpr="x+128" format="%.0f" min="-128" max="128" inc="1" storagetype="uint8" endian="big"/>
<table name="Percent Low Temp Timing Trim vs Coolant Temp" category="Timing" address="38b4" type="2D" level="2" scaling="Percent255">
<table name="Engine Temp" address="6f12" type="Y Axis" elements="8" scaling="Temp"/>
</table>
<table name="Base Low Coolant Temp Timing Trim Map #1" category="Timing" address="36cd" type="3D" level="2" swapxy="true" scaling="TimingTrim8">
<table name="Engine Load" address="5ce8" type="X Axis" elements="19" scaling="Load"/>
<table name="RPM" address="5cb6" type="Y Axis" elements="20" scaling="RPM"/>
</table>
<scaling name="ColdStartTime" units="ms" toexpr="x*0.008" frexpr="x/0.008" format="%.1f" min="0" max="500" inc="1" storagetype="uint16" endian="big"/>
<table name="IPW Adder for Cold Start #1" category="Fuel" address="2fc0" type="2D" level="1" scaling="ColdStartTime">
<table name="Coolant Temperature" address="5db0" type="Y Axis" elements="9" scaling="Temp"/>
</table>
<table name="IPW Adder for Cold Start #2" category="Fuel" address="4e72" type="2D" level="1" scaling="ColdStartTime">
</table>
Old Oct 25, 2008 | 12:33 AM
  #117
PeteyTurbo's Avatar
Thanks Bryan, I'll give it a shot tommorow..
</table>
</table>
</table>
</table>
Old Oct 25, 2008 | 12:56 AM
  #118
RazorLab's Avatar
Thank mrfred and l2r99gst
Add IPW at lower coolant temp, should help. Same thing the "cold start E85 kits" do.
Old Oct 26, 2008 | 12:55 PM
  #119
lan_evo_mr9's Avatar
Is this capable with 88590015-
<table name="Water Temp Enrich Starting #1" category="Fuel" address="3732" type="2D" level="1" scaling="uint8">
<table name="Water Temp" address="67BC" type="Y Axis" elements="9" scaling="Temp"/>
</table>
<table name="Water Temp Enrich Starting #2" category="Fuel" address="3742" type="2D" level="1" scaling="uint8">
</table>
<table name="Water Temp Enrich Running #1" category="Fuel" address="3712" type="2D" level="1" scaling="Enrich">
</table>
<table name="Water Temp Enrich Running #2" category="Fuel" address="3722" type="2D" level="1" scaling="Enrich">
</table>
<scaling name="Enrich" units="units" toexpr="x-128" frexpr="x+128" format="%.0f" min="-128" max="127" inc="1" storagetype="uint8" endian="big"/>
Old Oct 26, 2008 | 04:32 PM
  #120
mrfred's Avatar
</table>
</table>
</table>
</table>
The startup enrichment table for the 88590015 is in the first post of this thread. There is only one startup enrichment table that matters for the Evo 9. No one has found a table for the Evo 9 that affects enrichment for the few moments after the engine is started. Either it doesn't exist, or its more elusive than the other table.
