max boost on stock internals
Old May 28, 2008 | 05:46 PM
  #31
02 OZrally's Avatar
i run 23-24ish in mine with only 2 counts,but my clutch slips so the d@mn needle bounces lol...
Old May 28, 2008 | 06:01 PM
  #32
Asmodeus6's Avatar
26psi on the stock motor. 93 octane. And I mean 26psi from start thru redline. None of that stock turbo spike / taper crap. Driven like this daily. For 10,000 miles.
No head studs. Rod bolts, nothing. Just cams.
Meth is my next move so I can rediscover 'timing'. And... another 4-5 psi of boost.
Old May 28, 2008 | 06:05 PM
  #33
Ted B's Avatar
Originally Posted by tephra
I always thought that reducing backpressure was bad for low/mid range?
That is a common misunderstanding that is associated with normally aspirated engines. What is actually happening in that case is the size of the pipe reduces exhaust gas velocity to the point where it cannot scavenge the cylinder effectively at low rpm. Backpressure never did anything but reduce power.
With a turbo car, exhaust pulse tuning is only valid up to the turbine wheel. On the exit side, all you need is a pipe that is large enough to prevent pressure buildup at max mass airflow (max hp).
Old May 28, 2008 | 06:09 PM
  #34
Ted B's Avatar
Well ok, but your signature says this is a 3076R. Yes?
In tuning 'dude's car, we're able to get 29psi, holding above 22psi until just past 7k rpm with an EVO 8 TME and E85 (GM 3-port + JDM MAP). We're up to 310 load from 3500-5000rpm, but I'd like to see what the IATs are doing between 3-7k (as if I don't know), especially with this factory IC.
Old May 28, 2008 | 06:16 PM
  #35
Jorge T's Avatar
..I wish e85 was more readibly available here. There is a bad political campaing going on against ethanol in texas. even the news are giving misinformation about being cause of forming intake gunk and producing oil sludge.
Old May 28, 2008 | 06:29 PM
  #36
nonschlont's Avatar
Im currently pushing 23-24 psi @ 3400 - 4750 tapering down to 19.xx-20 @ 7500 w/ the stock cat on 91. seeing an occasional 1-2 counts. I just noticed Im pretty much maxing out my injectors by 7300. so u might wanna consider that as well, u might be maxing them out w/ a HFC/test pipe.
Old May 28, 2008 | 06:36 PM
  #37
Jack_of_Trades's Avatar
He's running FIC 1050's so IDC's aren't an issue for him right now
Old May 28, 2008 | 06:37 PM
  #38
MR Turco's Avatar
I am hitting the same boost by redline and holding 25ish from 3300-5900 and tapering to 19-20ish by 7500 also maxing out IDC but i think it is really the fuel pump running out of DC. this is all on the stock cat and catback with 93.
Old May 28, 2008 | 06:39 PM
  #39
Piro's Avatar
Well, I just blew my motor boosting 29lbs on stock studs, also my turbo shaft is very iffy,
I have alky injection and all other suporting upgrades but I was lazy and did not replaced the studs, now I have to replace a bunch of parts to get the car running again.
BTW the car felt like a rocket!!
Old May 28, 2008 | 06:53 PM
  #40
ApacheFixer's Avatar
sorry for the loss. but thanks for the valueable information
Old May 28, 2008 | 06:55 PM
  #41
tephra's Avatar
Not yet I am not.. but yeah 20psi @ redline basically max's out stock injectors..
however I am only worried about 3000-5500rpm at the moment...
Old May 28, 2008 | 06:56 PM
  #42
nonschlont's Avatar
Old May 28, 2008 | 06:57 PM
  #43
merkzu's Avatar
What alky kit? Did you tune the car yourself?
Old May 28, 2008 | 06:58 PM
  #44
tephra's Avatar
Wow impressive, stock cat+catback
Old May 28, 2008 | 06:59 PM
  #45
nonschlont's Avatar
damn... that sux! sorry to hear that.
