TephraMOD V5.8 - testing help required
Old Aug 8, 2008 | 09:25 AM
  #211
dawnduran's Avatar
Would you patch 96530006 (EDM Evo8 and update for USDM Evo8) please. Thank you.
Old Aug 8, 2008 | 06:36 PM
  #212
tephra's Avatar
yup...
what I plan todo is release 4 or 5 ROMID's with V5.10 and then the ones I miss I will slowly do 96530006 will be one of the first
and I will upload 5.10 later today... I just need to write up some xml bits for evoscan...
Old Aug 12, 2008 | 07:42 AM
  #213
denver's Avatar
Would there be any reason for an increase in knock with the 5.8 patch, or has anyone else experianced it? I had terrible knock counts during spool up, with all stock maps on a basicly stock car..... I switched back to the standard 015 rom, and the knock counts are gone.........maybe 1 or 2 occationally, but no where never the 8 to 25 i saw before. I know I need to still disable lean spool, but it is still enabled in the standard rom and there isnt knock.....I decreased timing during spool up, and it did reduce the knock but I thought it was odd switching back to a standard rom basicly eliminated the knock.
Im at work so I dont have any logs to post up, I was just curious if anyone had the same problem. I am going to try V5.10, as well, but right now I have some other issus to work out with the car so I wouldnt be able have a valid evaluation of the V5.10 yet.......
Old Aug 12, 2008 | 02:02 PM
  #214
EVOizmm's Avatar
it seems I see lots more knock counts during shifts and such from before. Its never bothered me to much as i knows its just some phantom knock.
Old Aug 12, 2008 | 03:59 PM
  #215
tephra's Avatar
post up a log or two
but there shouldn't be anything that causes knock in the 5.8 vs regular..
Old Sep 30, 2008 | 12:11 PM
  #216
Lancerguy'03's Avatar
any info on ROM ID 96420008 being released for any Version of the MOD...?
Old Oct 2, 2008 | 12:52 PM
  #217
bump for 96420008....and can anyone yet confirm that the 96420011 works or if can replace my ROM?
Old Jan 8, 2009 | 12:24 AM
  #218
abdulghaffar's Avatar
need evo 8gsr jdm ROM
Originally Posted by mfr122887
Anyone?
i have evo 8 2003 JDM gsr and i m using ecuflash1.3 software but the main thing my evo map parameters does not open . please if someone have its ROM so .plz email me on fastone_bacha@hotmail.com
richardjh
May 24, 2026 12:49 AM
tephra
Dec 26, 2023 01:11 PM
tephra
Aug 19, 2016 10:07 AM
tephra
Jul 25, 2016 02:21 PM
tephra
Mar 18, 2008 06:22 PM
