TephraMOD V5.8 - testing help required
Old Aug 6, 2008 | 04:40 AM
  #196
BarryC's Avatar
Originally Posted by tephra
BarryC has done the clutch switch install. Can't be too hard..
I dont want to start distributing XML - someone else needs to take ownership for 90550001 xml and they should keep it upto date. I will include the usual XML additional stuff...
yep I have the clutch switch installed its not an oem switch its a sort of diy job but works perfect you just need to ground one side of the switch and connect the other side to the ecu pin,
can post up a pic later if needed
Old Aug 6, 2008 | 05:33 AM
  #197
cossie1's Avatar
Your still alive then Barry
Old Aug 6, 2008 | 10:48 AM
  #198
justboosted02's Avatar
has anyone logged 1byte load in logworks yet?
would the log xml code be if logging from MUT 41;
<datachannel id="#41" name="1byteload" selected="0" units="load" min="0" max="255" expr="1.2*x" type="0"/>
Old Aug 6, 2008 | 12:44 PM
  #199
cpoevo's Avatar
Originally Posted by silver_evo
Smogrunner : make sure you are NOT in valet mode by pressing the pedal and starting normally. Then shutdown and goto ECUflash and change the Enable valet and Auto Valet mode to "0". Then re-flash and you will have disabled Valet mode.
I have used your instructions above and they work perfect. After a month of testing on my car everything works perfectly now. I have the external switch and it works great and I also tested using the ICS switch and it works great as well. Other the the Valet mode hiccup everything works perfectly.
Old Aug 6, 2008 | 01:31 PM
  #200
dudical26's Avatar
I will let you decide, changes in 5.9 (from 5.8):
- Really fix valet lock out (ie enable valet mode and then flash disable valet mode leaves valet enabled - and ppl can't start their cars)
- Include MUT entries for various things - easier for newbie ppl that don't understand MUT stuff.
What I might do is release 5.9 today/tomorrow and slowly upload images - rather than doing 5 or 6 in one go...
If you are going to include MUT tables with entires for common logging items already complete perhaps you would not mind providing a matching definition and evoscan settings file.
This is the last thing we need to complete the wiki. Once we have this, hoefully we can eliminate nearly ALL setup questions. The time spent now will hopefully pay of in the future. If you are going to release 1 ROM id at a time this might be a great oppertunity to build the WIKI download section.
Old Aug 6, 2008 | 07:20 PM
  #201
sub7's Avatar
Love to see your setup barry
So the the "switch" activate when you press the clutch?
Old Aug 6, 2008 | 09:00 PM
  #202
cpoevo's Avatar
I tried the SAS thingy and adjusted my idle using the BISS. Wow no wonder my car ran like POOPOO. As soon as I activated the SAS the car idled at like 450-500 and barely stayed running. Got it adjusted and the car idles smooth as silk, well as a newly paved road. Cams dont help the idle much. Thanks Tephra.
Old Aug 6, 2008 | 09:12 PM
  #203
tephra's Avatar
Don't thank me - wasn't my find
Good to hear your car is running better thou!
Old Aug 6, 2008 | 10:08 PM
  #204
cpoevo's Avatar
Sorry my dumb a$$ posted in the wrong topic thanking the wrong person.
So Tephra thank you for v5.8, it works nicely. I have been testing it for a month now and my MPG has gone up from 18mpg to 19.5mpg using a zeroed out WGDC.
Old Aug 7, 2008 | 06:58 AM
  #205
PessimiStick's Avatar
Any news on 5.9 for 88590015?
Planning on patching this weekend and I figured I might as well wait for 5.9.
Old Aug 7, 2008 | 07:01 AM
  #206
tephra's Avatar
I will try and get it out tommorow... hopefully it wont be a rush job
also it will be 5.10....
5.9 was a dev release which didn't fix a bug from ages ago
Old Aug 8, 2008 | 05:56 AM
  #207
Kracka's Avatar
Oh I hope v5.10 comes out today! I'm going to install my wideband and would love to take care of all this at once
Old Aug 8, 2008 | 06:22 AM
  #208
dudical26's Avatar
tephra did you see my post
here
it was the last one on the page, might have missed it.
Old Aug 8, 2008 | 06:46 AM
  #209
bump.....
Old Aug 8, 2008 | 09:12 AM
  #210
He said he was going to post when he gets up, so probably tonight for us.
