TephraMOD V5.8 - testing help required
Old Jul 23, 2008 | 05:06 PM
  #136
Smogrunner's Avatar
I think, once again, that one of the first things that could really help in here is to have someone like Jack_of_Trades (or similar member like nj1266) to moderate this part of the forum. IMHO, there is a REAL need for some general housekeeping in here. Also, this forum could possibly make good use of some sub categories: EvoScan, EcuFlash, Tuning, General setup, Latest Advancements, etc.
Old Jul 23, 2008 | 05:37 PM
  #137
tephra's Avatar
UPDATE uploaded 96420011 AND 88580014
ps - I haven't changed the MUT_TABLE yet so you will need to manually add the 1byte...
Old Jul 24, 2008 | 12:40 AM
  #138
8UpUrV8's Avatar
Originally Posted by Smogrunner
8upurv8,
The first post of this thread has 94170015 listed as ready to test:
Also, the first post of the huge tephra v5 patch thread lists both ROMs as ready:
https://www.evolutionm.net/forums/sh...d.php?t=332778
If you just want to switch from the 0008 to the 0014/0015 there should be no problems assuming you follow the right steps...
I have it donwloaded, I have it ready, but what's the right way to switch????
Copy/Paste 015 into my 008 file?!?
That's what I'm not sure about, and I really want to try V5!!!
Old Jul 24, 2008 | 03:28 AM
  #139
tephra's Avatar
forget your 08 rom, load the 15 rom and copy all your maps from your 08 rom into the 15 rom.
if this is your first tephra mods experience get someone to help you
Old Jul 24, 2008 | 07:36 PM
  #140
ohthree's Avatar
i'm loading my 15 rom in tomorrow, anyone test it yet?
Old Jul 24, 2008 | 07:47 PM
  #141
tephra's Avatar
apparently smoggy
still - treat is as though it hasn't been tested.
take the usual precautions and run through the usual basics tests before lead-footing-it
Old Jul 24, 2008 | 08:07 PM
  #142
Smogrunner's Avatar
I'm having a good time with 5.8, but I still haven't played with many of the features. NLTS is one the top priorities, but I'm starting to run out of free time.
One thing that I could use is a link that explains how to use all the features.
Old Jul 24, 2008 | 09:45 PM
  #143
Jim in Tucson's Avatar
Explaination is in this post.
Old Jul 25, 2008 | 09:48 AM
  #144
EVOizmm's Avatar
ETA on Rom ID 94170008?
Edit: I did some reading, and i should be able to just use the 94170015 RomID correct?
Old Jul 25, 2008 | 10:33 AM
  #145
Jumperalex's Avatar
you got it ... though at this moment it is considered "Untested" compared to say 014 which has been tested. So go ahead and test it for us >;-)
Old Jul 26, 2008 | 02:23 PM
  #146
mfr122887's Avatar
Yes, lean spool was disabled on my last rom. I haven't logged the new rom, but I will tonight or tomorrow. Thanks for the heads up.
To get lean spool enable/diable and to remove my EGR trouble codes and in 5.8, can I add the following tables? I copied straight out of my old 94170008 rom.
<table name="ECU Periphery0" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
<table name="ECU Periphery2" category="Misc" address="fca" type="1D" level="1" scaling="Hex16"/>
<table name="Lean Spool Enable " address="1681" type="1D" level="1" scaling="uint8"/>
<table name="Lean Spool Disable" address="1685" type="1D" level="1" scaling="uint8"/>
56DA is the value for table Periphery0
0DDF is the value for table Periphery2
48 is the value for the lean spool enable
48 is the value for the lean spool disable
Worth a try? I just worry that the 0008 and the 0015 roms are too different...
What is the proper way to disable lean spool? Disable it by setting the enable/disable to the same RPM or by disabling it in the periphery bits? Thanks
Old Jul 26, 2008 | 08:00 PM
  #147
EVOizmm's Avatar
i tried out tephra mod v5.8 on RomID 94170015 and so far everything is working perfect, no issues as of yet.
Old Jul 27, 2008 | 11:14 AM
  #148
Smogrunner's Avatar
The one thing that I don't like about the Tephra patch is the requirement to hold the gas pedal down with a fresh ignition in order to start the car.
I have an Exedy Triple Carbon clutch that is a real workout to use and I stalled the car a couple of days ago. I caused a traffic jam and missed the green light having to turn the car off and hold the gas pedal down waiting for the slow CEL to restart the car.
How do I completely disable this feature? I changed the "1s" to "0s" for both Valet options in the Tephra mods map in EcuFlash and then the car wouldn't start no matter what.
Old Jul 27, 2008 | 11:58 AM
  #149
silver_evo's Avatar
Just put 94170015 implace of a stock 94170008 on a 2003 USDM EVO 8 ill,let ya know how it goes.
Old Jul 27, 2008 | 12:11 PM
  #150
Smogrunner's Avatar
Am I the only one who can't seem to figure out how to disable the start up function where you have to depress the gas pedal?
Silver Evo, please, get us informed.
