Evo 10 - Ecuflash - 3 tables
Old Jul 11, 2008 | 11:44 AM
  #136
TTP Engineering's Avatar
It will not be $100. With EcuTeK at $750 which does not always include dynotime, it will be a more effective pricing model, faster results, no need to make an appointment and a flat XXX gain in power and tq. The unit will be PNP.
We are putting the X back on the dyno today to try and break the 100whp mark on the ZChip on the stock Evo X.
Old Jul 11, 2008 | 12:45 PM
  #137
Chabada15's Avatar
good luck guys...i better get to work on my evo else sum X's over here might actually start boogeying
Old Jul 11, 2008 | 03:50 PM
  #138
antics22's Avatar
alrighty then... lets keep this thread focused on ECUFLASH please... Other innovative products can go in their respective vendor forums and/or sections.
Stay on topic please....
Old Jul 11, 2008 | 04:10 PM
  #139
Chabada15's Avatar
and steve yes dumping 3k+ into suspension and wheels should make it nimbler, but do the same for an 8 or 9 and your back to square one, im saying stock for stock
Old Jul 11, 2008 | 09:50 PM
  #140
StevenStarke's Avatar
last off topic post...
Chaz, I'll drive a stock X circles around a stock 8/9. Stock for Stock the X handles better. Research any track time. Other then straight aways, X's do better on the track. The 9 only had them on straights, but then again, I think I remember a test with an evo 6 beating up a 9 on straights too, so newer models losing on straight is nothing new. But as evolution of the evolution keeps goin, newer models handle better. And I'm into suspension and wheels/tires for around 5k sir,
Old Jul 18, 2008 | 12:10 PM
  #141
any updates on this? I know the cable has been delayed until 7/31, but how about the programming?
Old Jul 18, 2008 | 12:55 PM
  #142
Thegame's Avatar
Originally Posted by Steve@NrgTech
any updates on this? I know the cable has been delayed until 7/321, but how about the programming?
What were you trying to type? 7/21? Or 7/31? But it should be out this month, right?
Old Jul 18, 2008 | 12:56 PM
  #143
whoops, lol
fixed
Old Aug 13, 2008 | 04:45 PM
  #144
dark-evo's Avatar
its USDM EvoX Rom
http://forums.openecu.org/viewtopic.php?p=18669#18669
Old Aug 13, 2008 | 04:51 PM
  #145
mrfred's Avatar
Originally Posted by dark-evo
Awesome. Now the fun can really begin! This will really speed up the Evo X ECUFlash tuning curve.
Old Aug 13, 2008 | 05:02 PM
  #146
cossie1's Avatar
Are there any xml's for the other rom yet ?
Old Aug 13, 2008 | 05:03 PM
  #147
dark-evo's Avatar
why not?
Old Aug 13, 2008 | 05:10 PM
  #148
dark-evo's Avatar
Smile
haha yes
<map name="l" type="1" active="1" help="" class="1" map_struct="" level="0">
<data count="21" offset="#FFFD2" storagetype="uint8" func_2val="[value]" func_val2="[value]" format="%.2f" metric="" caption="" desc="" inc="1" incb="5" incdata="0" incdatab="0" inc_dir="1" cols="1" view="char" color_dir="1"/>
</map>
Old Aug 13, 2008 | 08:50 PM
  #149
evostang's Avatar
Do you all think the freeware version of IDA4.9 or the trial version of 5.2 would do the job? Not really wanting to spend the money on 5.2 standard without seeing what I'm getting into.
Old Aug 13, 2008 | 10:24 PM
  #150
EFIxMR's Avatar
looks like the offset for...
low ign
hi ign
fuel hi
fuel lo
fuel hi 1
fuel lo 1
injector latency
boost cut
are the same as the ones i posted for the EDM rom.
however the mivec, boost wg, boost target tables are all different as well as all the RPM scalings and load scalings.
ign load offset 60f76 elements 22
ign rpm offset 616f4 elements 23
fuel load offset 63cc6 elements 21
fuel rpm offset 63d1e elements 16
injector scaling offset 6512e elements 7
boost cut scaling offset 651ca elements 9
That's what i can find so far in 10 mins... More searching in a bit.
