Evo 10 - Ecuflash - 3 tables
Old Jun 7, 2008 | 02:57 PM
  #61
nj1266's Avatar
This is fantastic. I cannot believe it is happening so quickly. I wonder when the other flashing software will leave the Evo market....Again.
Old Jun 7, 2008 | 04:33 PM
  #62
mrfred's Avatar
Originally Posted by dark-evo
Mh8106f
I can't find any cross references between that ID and the processor family names.
Old Jun 7, 2008 | 07:07 PM
  #63
Mr. Evo IX's Avatar
mrfred. I think that might be a memory register to the can interface.
page 13-63 is very similar type address.
http://documentation.renesas.com/eng...48_32180um.pdf
Old Jun 8, 2008 | 12:38 AM
  #64
clck's Avatar
evoX Map Addresses
My contribution..
Manage to locate all/most 3D map addresses and subsequent hex dump.
Hope this will speed up the production of xml file.
File Type: zip
Old Jun 8, 2008 | 01:07 AM
  #65
agron25's Avatar
good job
Old Jun 8, 2008 | 01:15 AM
  #66
fostytou's Avatar
EvoM Community Team
You guys are ******* crazy! Good work!
Old Jun 8, 2008 | 02:20 AM
  #67
jcsbanks's Avatar
I'm in
"The EIT vector entry is located at the beginning of the internal ROM/extended external areas. The branch instruction
for jumping to the start address of each EIT event processing handler is written here. Note that it is the branch
instruction and not the jump address itself that is written here."
The first bytes are actual code, not a vector... change it to code and you can start to disassemble the code. I'm moving house in 48 hours and have boxes everywhere, wish I could play more! I still get some register errors so I think we need the right processor definition or setup.
Old Jun 8, 2008 | 07:56 AM
  #68
EFIxMR's Avatar
boost cut offset: 555b4
boost cut rpm y axis: 60ff0
Old Jun 8, 2008 | 09:43 AM
  #69
EFIxMR's Avatar
Found some more stuff, but it could be hit and miss
-Injector Latency
Battery Voltage Scale Offset: 608fc elements "7" - 99% sure correct
Injector Latency MS Offset: 556cc - 45% sure
-Boost Target Maps 1-2-3 ???
Offset: 5e623
Offset: 5e719
Offset: 5e80f
scaling uint8??? or possibly boostbar???
X axis offset: 61690 scaling boostbar?? elements "14"
Y axis offset: 63710 RPM?? elements "17"
Any input on these maps would be much appreciated!
Old Jun 8, 2008 | 11:12 AM
  #70
kalex's Avatar
See text at addr 0185C in the EVO-X dump...
Old Jun 8, 2008 | 12:21 PM
  #71
MalibuJack's Avatar
Nice.. I definitely will be getting myself a new CAN/Openport cable, and an ECU and building a bench harness to work at it sometime in the future.
I have to buy a new car some time in the future.. It might end up being an X or Ralliart (the AWD turbo if they release it) so I've been watching this stuff, but not participating much.
Old Jun 8, 2008 | 12:30 PM
  #72
DarksideEng's Avatar
You guys are awesome. I wish I had the slightest clue as to what you are talking about so I could help.
Old Jun 8, 2008 | 12:51 PM
  #73
RazorLab's Avatar
Offset: 5e623
Offset: 5e719
Offset: 5e80f
Here it is with WGDuty:
Could be right? Although I would think that the table should be BoostBar and X should be load or even TPS since it's a 3D boost table but none of the loads or TPS/voltage work.
Old Jun 8, 2008 | 12:59 PM
  #74
RazorLab's Avatar
Injector MS looks off but voltage looks spot on:
Old Jun 8, 2008 | 01:07 PM
  #75
Jack_of_Trades's Avatar
Its crazy that I forsee the X ECU to be almost completely disassembled before there is even enough aftermarket goodies to slap on one of them,lol. I guess the VIII and IX's were a practice run to get everyone ready to rip the X ecu apart haha. Great work guys. Damn I want an X now.
