TephraMod V5 88590015 - Evo 9 - Help
Old Jun 16, 2008 | 10:56 AM
Done's Avatar
I installed everything perfectly, and it runs perfectly. Only problem, the directions instruted me to deleted my high/low 2,3 timing tables. I went ahead and deleted them.
Now the issue.... The car still uses the 2,3 tables. I make changes in my high 1 table and the do not effect the cars timing in boost.
Any ideas?
Do I need to reload ecuflash and get the definitions for the High 2,3 tables again?
Old Jun 16, 2008 | 10:57 AM
TouringBubble's Avatar
I just kept my tables since I tune cars that don't have the patch as well. Someone can probably toss you the XML you need so you don't have to add everything else back in. I would but i don't have my laptop here at work.
Old Jun 16, 2008 | 11:20 AM
Done's Avatar
yeah i would be greatful just to get the xml back, so I dont have to reload everything.
Old Jun 16, 2008 | 03:57 PM
tephra's Avatar
what do u mean its still using table 2 and 3?
Old Jun 16, 2008 | 04:02 PM
Done's Avatar
When I download the rom off the car, The High/low 2,3 ignitions maps are still there and being used. Although i dont have access to them anymore in ecuflash.
Did i miss something where the car would only read off the high/low ignition 1 map?
for example i set timing at 250ecuload at 8 degrees, its still only going 5 degrees because that is what was set in high/low 2 table.
Old Jun 16, 2008 | 06:20 PM
tephra's Avatar
yes they remain there but shouldn't be used.
what romid?
are you actually using the V5 rom? ie do the V5 settings show up correctly in ecuflash?
are you on normal or altmaps?
post up that bit of the log?
Old Jun 16, 2008 | 06:26 PM
Done's Avatar
im on normal not alternative.
and when i make adjustments in high timing 1, nothing changes.
Ill get a log up
Old Jun 16, 2008 | 06:55 PM
tephra's Avatar
maybe your XML is wrong as well, can you post your high ignition segment?
PPM
Apr 2, 2015 09:35 AM
5LEEPERISAH23I
May 17, 2010 09:54 AM
NOMIEZVR4
Oct 26, 2009 10:36 PM
Mattjin
Oct 11, 2009 03:11 AM
Evo_Jay
Aug 21, 2009 10:06 PM
