have problem with knock retard
Old Jul 14, 2008 | 03:39 PM
KOTT's Avatar
mods on evo 8 mr : 3"exh, 272/264 cams with hi lift, ams ic, avc-r, presicion 880 inj, evo 9 20g turbo
after long tuning this injectors i have next numbers
scaling : 731
latency :
3.312
2.184
1.32
0.792
0.696
0.36
0.24
problem : i have huge knock retard(10-15 sometimes 20+ degrees )
afr i sabout 10.9-11.2 and VERY low ign timing, sometimes have knock voltage 2.0v+, but sometimes when knock voltage is normal knock retard stil big, and sometimes when knock voltage 2.0v+ ecu doesnt retard ign....
i cant understand why ecu retard ign...(((
Old Jul 14, 2008 | 05:41 PM
RazorLab's Avatar
What are you using to log? Evoscan? What is the actual knock sum and not knock voltage?
Stock ecu?
Old Jul 15, 2008 | 03:20 AM
KOTT's Avatar
i use ecuedit, and i havent knock sum((
Old Jul 15, 2008 | 03:31 AM
LION evo's Avatar
get evoscan!
Old Jul 15, 2008 | 03:39 AM
KOTT's Avatar
mb will try, but now have ecuedit((
Old Jul 15, 2008 | 03:40 AM
KOTT's Avatar
мог бы уже и по руски написать)))
Old Jul 15, 2008 | 08:32 AM
justboosted02's Avatar
Вам необходимо получить evoscan и взглянуть на стук сумм. Напряжение ничего не значит для нас
Old Jul 15, 2008 | 01:54 PM
KOTT's Avatar
ty, i understand it
will try to get evoscan, or find sum in ecuedit
Old Jul 15, 2008 | 07:55 PM
absubtle's Avatar
scaling : 731
latency :
3.312
2.184
1.32
0.792
0.696
0.36
0.24
What spark plugs are you running? Perhaps you are too lean on boost ramp up, causing knock.... (low rpm, rising load, timing will be high-like 30 degrees). Have you checked your MAF? They get dirty, dirtier-than-**** w/ the stock turbo.
Your load may be off in those places causing high timing... causing knock.
Absubtle
CO
Old Jul 16, 2008 | 03:02 AM
KOTT's Avatar
knock retard=knock sum... author of ecuedit said me it
2 absubtle
we have cleaned MAF, dont help(
will try change spart plugs...
and about lean on boost... afr is rich in all rpm... 10.7-10.9
Old Jul 16, 2008 | 03:16 AM
evo828's Avatar
OK. So if you KnockSum=Knockretard - then by getting 10 knock sum you really retard around 3-4* on timing.
Post your ign map and may be some log (TPS, RPM, Load, WB, KnockSum, MAP, IgnitionTiming)
Old Jul 16, 2008 | 01:26 PM
KOTT's Avatar
this is my ign map
Old Jul 16, 2008 | 01:33 PM
KOTT's Avatar
part of my log, not worst
Old Jul 16, 2008 | 01:36 PM
burgers22's Avatar
You look to be running the timing quite high above 6000 RPM, try reducing it in the area were you get knock.
MB
Old Jul 16, 2008 | 01:44 PM
KOTT's Avatar
doesnt help(
on "off"(avc-r) i stil have knock((( (~0.7-0.8bar)
i think it maybe something else?
need help...
