post your e85 fuel maps!
i already checked all that and there are no leaks period.....i know from experience when there is an exhaust leak at my down pipe i had a **** load of them on my 04 evo so with this one i made sure everything is ok b/4 the w/b went in and i check 3 days ago and everything was cool
idk there might be somethign up with my fuel system of maybe in the mods i chose?
my 04 was only on stock injectors but when trying to tune it, it never made the power it should have but my injectors where always maxed out.
well i swapped all my 04 evo bolt ons to my 06 evo and it seems to be having the same problem it seems like something is straining my fuel system to get more fuel into it to make the same power as everyone else.
right now i upped the 11v latency and it actually made my afr richer up top so imma keep on with this route and get them lower.
but it sucks where everyone else that is running e85 there idc is at 50-65% im at 103% just to be where they are. and i have no idea y my cars where like that?
what does the average e85 on 1000cc have in idc then?
i was told this by a pretty big socal tuner the is kinda of marketing on the fact that he tunes e85 and has experience in it? .....to his credit though he did give me a **** load of good info an dgot my on the right track to tuning for this stuff.
also how do i monitor fuel pressure?
IDC also depends on how much boost you are running, and of course AFR. If you are running something crazy like 13.7 (like you mentioned in your first post) AFR then of course the IDC will be much lower than if you are running something like 11.5-12.0 AFR.
I think posting your fuel map will answer some questions as well.
