Need some help with GM Boost Control
Old Aug 8, 2008 | 03:45 PM
fixem2's Avatar
Anyone had an issue with the GM controller when going WOT your car will only boost to 15psi, but when you let off and punch it again you get full 23psi boost?
Old Aug 8, 2008 | 04:13 PM
RazorLab's Avatar
Have you logged error correction?
Old Aug 14, 2008 | 11:56 AM
fixem2's Avatar
logging error correction and get zero across the board. Wondering if the Evoscan request ID is different for the 96530006 ROM.
Old Aug 14, 2008 | 12:35 PM
John F's Avatar
Evoscan logs Error Correction fine for me on 96530006. Request ID is 8A.
Old Aug 14, 2008 | 12:52 PM
fixem2's Avatar
There is my issue. That is Boost Error for me and WGDC Correction is 8B.
Old Aug 14, 2008 | 04:00 PM
John F's Avatar
Now I have confused myself. I was mixing up boost error and error correction. I have:
Wategate Duty Cycle 86
Load(boost) Error 8A
WGDC correction 8B
Load Error is from your "Turbo Boost Error Correction" table in Ecuflash and will range from -20 to 20. Load error will usually read -20. You want it to read around 0 when you have reached full boost and stay there as far as possible up to max revs.
Have a look at this https://www.evolutionm.net/forums/sh...d.php?t=357766
Sorry for the confusion.
Old Aug 14, 2008 | 04:39 PM
tephra's Avatar
You need to program the MUT requests... its part of doing the direct boost mod... dont forget
nj1266
Jan 25, 2026 01:43 AM
Tbtalon94
86
Sep 24, 2010 12:45 PM
iTzBoosTn
Northeast Region
Jul 12, 2009 11:24 AM
sspaladin28
14
Jun 22, 2009 12:57 PM
Hiboost
14
Oct 12, 2008 12:51 PM
