TephraMOD V5.10
Old Oct 20, 2008 | 08:20 PM
  #496
Jeff_Jeske's Avatar
^ You know what I did the same thing..... built the new ROM in 1.39 and attempted to load it on my ECU tonight (after reading that) and it didn't work either. No connection.
Old Oct 20, 2008 | 08:22 PM
  #497
Jeff_Jeske's Avatar
What is the newest EVOScan that actually works with this mod?
I'm also still using Version .99 because it actually worked but the last few didn't seem to play nice with the modded roms.
Anyone care to share their data files for a newer working version of EVOscan?
Old Oct 21, 2008 | 03:42 AM
  #498
cossie1's Avatar
Some older versions of ecuflash
http://www.openecu.org/downloads/
And the new version 1.40
Old Oct 21, 2008 | 04:25 AM
  #499
justastockevo's Avatar
any news regarding 88840017?
sorry, i know, i just being impatient...
Old Oct 21, 2008 | 06:10 AM
  #500
fixem2's Avatar
Ecuflash 1.38 works well with Tephra 5.10.
Old Oct 21, 2008 | 06:37 AM
  #501
tephra's Avatar
Sorry about 88840017 - I havn't forgotten you, just got sidetracked with other things.
I will try and get it up and running this week...
Old Oct 21, 2008 | 07:14 PM
  #502
EvoIXMR's Avatar
tephra - I have a quick question regarding stuck fuel trims....Not sure if this is v5.10 bug . I cannot log fuel trims for Mellon and not sure whats causing this. I reset the battery more than once and it gets stuck at 5.9 one time around and then .1008 the next time around. It won't budge at all, diff load in gears, diff rpms etc...Any ideas?
Old Oct 21, 2008 | 07:24 PM
  #503
tephra's Avatar
what if you just let the car idle for like 5 mins - does the idle trim change at all?
Old Oct 21, 2008 | 08:07 PM
  #504
EvoIXMR's Avatar
nope, nothing at all
EDIT - I can try again tomorrow after leaving battery unplugged...
Old Oct 21, 2008 | 08:28 PM
  #505
tephra's Avatar
you don't need to disconnect your battery..
what are you logging in evoscan? (RequestID's please)
Old Oct 22, 2008 | 04:43 AM
  #506
Kracka's Avatar
Is it possible that the valet mode (where you hold down the gas pedal with ign on but engine off) is interfering with bleeding the ACD system (where you also hold down the gas pedal with ign on but engine off)?
Old Oct 22, 2008 | 07:52 AM
  #507
EvoIXMR's Avatar
Tephra - still a n00b, what are request ID's, you mean these? Sorry...
TPS
RPM
TimingAdv
O2Sensor
InjPulseWidth
Battery
LoadCalc
load2byte
KnockSum
AFRMAP
Wideband A/F Ratio (Zeitronix)
Old Oct 22, 2008 | 09:17 AM
  #508
FastAzzEvo's Avatar
i looked at first post, but still don't have instructions..
can someone do a how to to install this on my ecuflash
Old Oct 22, 2008 | 11:13 AM
  #509
EVIL_EV0's Avatar
What version of EVOScan actually works with this patch by only adding the XML in post #1?
I'm still running 99 because all the latest and greatest EVOScan releases were buggy. Is there a new one that actually works?
Old Oct 22, 2008 | 11:26 AM
  #510
Mellon Racing's Avatar
2.4 was the last good version...2.5 busted the nb02 and wb02 gauges but it does log the data properly and I've let Hamish know about that.
