TephraMOD V5.10
Old Feb 9, 2009 | 08:49 PM
  #826
b16a95eg's Avatar
this is my native romid no cel's before, the only one i have now is rear o2 sensor because i just put my wideband in, i dont have a log of the garage test, what should i log for you? do you want the realtime graph? i'm gonna be going to bed here its 11pm so i'll get back to you in the morning, i'll check this before i log it,
Old Feb 9, 2009 | 09:06 PM
  #827
tephra's Avatar
whenever is fine.
log - rpm, tps, ipw, speed, load 1byte (preferably), timingadv....
just a csv section of when you push the clutch will be fine...
Old Feb 10, 2009 | 05:27 AM
  #828
b16a95eg's Avatar
ok will do, i need to add that code from the first page of this to log 1byte from evoscan right? if so do you do it the same way as adding it to the rom?
Old Feb 10, 2009 | 11:05 AM
  #829
b16a95eg's Avatar
ok i sent you an email with my log
Old Feb 10, 2009 | 04:42 PM
  #830
b16a95eg's Avatar
i think i misread the 1 byte load, i think i clicked 11bit4, so that log is probably useless i sent
Old Feb 10, 2009 | 06:47 PM
  #831
tephra's Avatar
ok resend it with 1byte load
ps - tps normally is about 13.3% withing 2-3% is probably fine..
Old Feb 10, 2009 | 07:56 PM
  #832
b16a95eg's Avatar
ok this time it worked? but now i have another question, how do i work valet mode? i set it to 0 in the mod options thing, thinking that would disable it but it didnt, so how do i disable it, and set it up so if i need it its there? i wouldnt push the gas in at all when i start it, but it was still going into valet mode
Old Feb 10, 2009 | 08:00 PM
  #833
tephra's Avatar
u got autovalet disabled as well?
the car CEL should flash at you when you first key on if valet is in affect!..
Old Feb 10, 2009 | 08:27 PM
  #834
b16a95eg's Avatar
yeah i put both to 0, but the cel still flashed at me, i'll try it again tomorrow though
Old Feb 10, 2009 | 08:30 PM
  #835
tephra's Avatar
hrmm... not sure whats going on there.
Old Feb 10, 2009 | 08:41 PM
  #836
b16a95eg's Avatar
this is kinda off topic, but do you use evoscan? i cant get my map tracing to work for the life of me, i'm using v2.5
Old Feb 10, 2009 | 08:43 PM
  #837
tephra's Avatar
yes - but I dont use maptracer... sorry
Old Feb 10, 2009 | 08:47 PM
  #838
b16a95eg's Avatar
ok thanks, i'll let you know if i get the valet mode right
Old Feb 11, 2009 | 09:07 AM
  #839
jcsbanks's Avatar
Does 1 byte load work for 88570008? I just get 0 from request ID 41? Also the 2 byte stuff is not present, is this related?
Old Feb 11, 2009 | 02:30 PM
  #840
tephra's Avatar
damn - I didn't fill out the MUT_TABLE.
must have been having a bad day
u can setup MUT41 to be 0x840B and that should fix 1byte load...
