Need Addresses for Lean Spool Start/Stop for 94170015/14
Old Aug 11, 2008 | 10:19 AM
chmodlf's Avatar
Can someone provide the addresses for Lean spool start/stop for 94170015?
For that matter does anyone want to share their xml from their 94170015 or 14? Once I finish mine I will share. It will contain lean spool, JDM Map, etc.
Old Aug 11, 2008 | 11:05 AM
cossie1's Avatar
<table name="Lean Spool Start RPM" category="Fuel" address="1680" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="Lean Spool Stop RPM" category="Fuel" address="1684" type="1D" level="1" scaling="RPMStatLimit"/>
Paste that into your evo7base.xml
Old Aug 18, 2008 | 05:11 PM
steadly2004's Avatar
Whats there to share, isn't it provided with ECUflash?
Old Aug 18, 2008 | 06:01 PM
chmodlf's Avatar
There are a few errors in the xml.
Old Aug 18, 2008 | 06:25 PM
Oh, ok
Old Aug 18, 2008 | 07:25 PM
Jumperalex's Avatar
in version 1.35? where? and the lean spool addy's are already there
Old Aug 19, 2008 | 12:49 PM
chmodlf's Avatar
OK Ace. I stand corrected...Guess I will not be sharing. Probably easier this way.
Old Aug 19, 2008 | 12:55 PM
Jumperalex's Avatar
Hmmmm not sure if that was meant in a less than positive tone, but I wasn't trying to be cheeky myself. I really was serious, if you found errors I wanted to know where so I could change them in mine.
Old Aug 19, 2008 | 01:12 PM
PessimiStick's Avatar
The default lean spool disable is wrong on Evo9base.xml in 1.35, it might be for others as well.
Old Aug 19, 2008 | 01:22 PM
chmodlf's Avatar
I am just wary of posting modded xml for those who do not know what they are doing. I don't want to be responsible for peoples engines.
Old Aug 19, 2008 | 02:50 PM
Jumperalex's Avatar
chmodlf oh you won't be responsible. it is their responsibility. It isn't like this stuff isn't already posted on EvoM, yours would just be another source. There is plenty of info, especially in the wiki, to guide people to making the mods they need.
I do feel ya that you don't want to lead people astray, but corrections to errors should most certainly be posted. Consider that more damage could be done by an incorrect value correctly used, than a correct value incorrectly used.
PessimiStick ahh fair enough. As far as I can tell it is right in 1.35 for 94170015 based on my experience. No doubt my fuel got WAY richer by changing the table values for Lean Spool Start/Stop
EDIT: PS ... a modded XML can't hurt a persons car in and of itself unless they go ahead and use that definition to modify the value in the ROM ... so really posting a modded xml is as benign as anything else we've posted on this board that could grenade someone's motor.
Old Aug 24, 2008 | 12:31 PM
Chabada15's Avatar
how would i go about disabling lean spool altogether?...and im at a loss, my lean spool start is at 3200 and stop is at 1250, does that make sense??? any help is much appreciated
Old Aug 25, 2008 | 09:18 AM
The general way to disable it is to set the start and stop RPMs to the same value. I think mine are at 1250 or something, though I'm not sure the actual number matters. (But lower is probably better, in case it were to spike lean for a second before it checked to disable or somesuch.)
Buchko
Outlander Sport
Apr 7, 2017 04:27 PM
Raceghost
Nov 18, 2016 03:10 AM
David Buschur
Sep 8, 2010 12:34 PM
Pd1
Oct 11, 2009 05:17 PM
evoredy
Feb 7, 2009 05:38 AM
