New Maps for Evo 7 and 9
Old Nov 5, 2008 | 02:52 PM
  #241
Deepnine's Avatar
I think one thread for each rom, is the best solution. There everybody can post new maps and discuss them.
I know lots about the 90550001 rom, but nothing about other roms, because i don't have anything to do with them. Maybe someday this will change, i have to start searching again.
Old Nov 5, 2008 | 10:18 PM
  #242
Mattjin's Avatar
I already have the 80700010 thread, it is just up to others to get their own running. The best thing is to compile all of the known maps yourself and start the thread with an updated XML attached so that everyone is on the same page.
Just keep an eye out, because once maps are found for one rom it is very easy to spot the same map in another rom. Most of the main functions are almost identical from the 7 through to the 9, just minor differences and new functionality set them apart.
Old Nov 21, 2008 | 12:43 AM
  #243
Deepnine's Avatar
for 90550001 can someone confirm?
I have no ida here at the moment, i did it only with a texteditor by comparing with other roms. I'm not 100% sure.
<table name="Thermo Fan Duty" category="Misc" address="43d2" type="3D" level="2" swapxy="true" scaling="Percent (128)">
<table name="Conditions" type="Static X Axis" elements="9">
<data>On1</data>
<data>On2</data>
<data>On3</data>
<data>Off1</data>
<data>Off2</data>
<data>Off3</data>
<data>A/C1</data>
<data>A/C2</data>
<data>A/C3</data>
</table>
<table name="Engine Temp" address="513e" type="Y Axis" elements="12" scaling="Temp"/>
</table>
<table name="Thermo Fan Duty #2" category="Misc" address="4c48" type="3D" level="2" swapxy="true" scaling="Percent (128)">
<table name="Conditions" type="Static X Axis" elements="3">
<data>On</data>
<data>Off</data>
<data>A/C</data>
</table>
</table>
Old Nov 21, 2008 | 12:09 PM
  #244
Mattjin's Avatar
Those are the correct maps. The smaller map is for Stationary and up to around 20km/h. The larger map is for greater than 20,50,80 km/h from left to right.
Old Dec 12, 2008 | 03:44 PM
  #245
Ted B's Avatar
Has anyone resolved the Decel Fuel Cut Delay and Cooling Fan maps for 94170015?
Originally Posted by honki24
Forgive me for not quoting the person, but I've copied all the important post info into a word document.... but in regards to this:
thanks!, beat me to it...
here are the rest for 0008
<table name="Decel Fuel Cut Delay - Neutral A/C Off" category="Fuel" address="42bc" type="2D" level="2" scaling="uint8">
<table name="Load" address="650a" type="Y Axis" elements="7" scaling="Load"/>
</table>
<table name="Decel Fuel Cut Delay - In Gear A/C Off" category="Fuel" address="42ca" type="2D" level="2" scaling="uint8">
</table>
<table name="Decel Fuel Cut Delay - Neutral A/C On" category="Fuel" address="42d8" type="2D" level="2" scaling="uint8">
</table>
<table name="Decel Fuel Cut Delay - In Gear A/C On" category="Fuel" address="42e6" type="2D" level="2" scaling="uint8">
</table>
<table name="Decel Fuel Cut Ignition Retard" category="Fuel" address="4300" type="2D" level="2" scaling="Timing">
<table name="Engine Speed" address="61da" type="Y Axis" elements="10" scaling="RPM"/>
</table>
What is the 94170014 equivalent? The variables look fine but load is crazy. Which load scaling should I use?
This is what I see:
Old Dec 15, 2008 | 08:02 AM
  #246
Ted B's Avatar
Bump . . . .
Old Jan 10, 2009 | 03:41 PM
  #247
nitz's Avatar
i'm having throttle hang issues after partial throttle cruising. has anyone resolved this using the decel fuel cut tables? have the tables been defined for 96260009?
Old Jan 11, 2009 | 03:58 AM
  #248
evoredy's Avatar
Originally Posted by Ted B
Bump . . . .
those tables you quoted should be identical to the 015. you probably already figured this out though.
i'm not sure if the 08 locations are correct/functional though. any insight on that/may be a reposted question?
Old Jan 18, 2009 | 11:09 AM
  #249
Slo_crx1's Avatar
I'm interested in these decel tables as well, mine hangs after part throttle quite a bit and it's rather annoying, especially in traffic.
Old Jan 18, 2009 | 01:02 PM
  #250
Ted B's Avatar
Bump for the same - 94170015
Old Jan 19, 2009 | 09:16 AM
  #251
Appauldd's Avatar
Originally Posted by evo828
I've put updated 96530006 and evo7base on 96530006 wiki page - including the primer tables.
http://evoecu.logic.net/wiki/96530006#Download
direct link:
http://evoecu.logic.net/images/4/42/...s_20081101.zip
Any chance of having these for the 94170015 ? ? ?
PLEASE !
Old Jan 19, 2009 | 01:25 PM
  #252
mplspilot's Avatar
PLEASE !
Having what?
http://evoecu.logic.net/wiki/94170015
Old Jan 19, 2009 | 02:48 PM
  #253
Appauldd's Avatar
That one isn't updated with all of the new findings.
I am looking for it and the base7 with all of the new findings already written in. I am not a coder, but I am willing to test new developments in the code if it is set up for me.
Make sense?
Old Jan 19, 2009 | 03:55 PM
  #254
mplspilot's Avatar
I dunno. Not really. If you're looking for the ROM, there is the link..
If you're looking for certain definitions for xml file, you need to specify what is it that you're looking for. Also this thread has definitions for 94170015. So either you didn't bother to read the thread or looking for something else. In which case, again, you have to specify.
Old Jan 20, 2009 | 02:47 AM
  #255
Slo_crx1's Avatar
What I'm looking for in particular is the definition for the decel cutoff table that was found for the 94170015 rom. If it's been posted in this thread previously then I apologize as I must of looked right over it. All I thought I saw was for 94170008.
