What is the point of this timming block? Pic
Old Aug 27, 2008 | 11:32 PM
Turbo Kyle's Avatar
So since I have been tunning I have been looking at my other friends maps. This is a RACE timming map for the old 20G 5 blade setup. Is this so you can shoot fire? Or does it help the spool of the turbo by taking out the timming at low load on the shift?
Old Aug 27, 2008 | 11:51 PM
PeteyTurbo's Avatar
It's to shoot fire I am guessing but I am guessing it = fail by looking at it..If you do it right you can get an ignition that may slightly help spoolup up going to the next gear..
I have done alittle tweaking to get a "pop" between shifts and I have heard it sometimes shoots flames but I mainly just did it because I was expermenting andjst kept using it because I like the sound..My car is quiet as hell but you can hear it when I shift..And it is definitely not like the map above and also has changes in the fuel table as well. You can hear it in this vid, I am the gray evo racing in the 2nd race.
http://www.motionbox.com/videos/069adfbb1318e58f
Old Aug 27, 2008 | 11:58 PM
Turbo Kyle's Avatar
Cool, just wondering and learning You chit is Movin'. Whats your mods?
Old Aug 28, 2008 | 03:47 AM
tkklemann's Avatar
Yeah, that's basically what it's for, although you might get better results taking about 10 degrees out of that area. But, you might hit the car behind you with the flames.
That ignition map could use LOTS of work. I bet that particular car doesn't drive very smooth, or, as smooth as it could be.
Abacus
Sep 18, 2025 05:44 AM
Abacus
Dec 6, 2021 05:45 PM
tscompusa
Apr 17, 2017 11:47 AM
Abacus
Feb 10, 2016 10:59 AM
Spec-OpsMotorsports
Aug 27, 2015 05:04 AM
