Evo 8 Reflash went wrong.. HELP
Old Sep 2, 2008 | 11:41 PM
evonsti's Avatar
today we try to reflash th eevo 8 useing ecu flash n when the map done load we try to start the car no good n then we try to load a stock map still no good such on ..
ps.. we drivet he car perfect all everything before we trything
anyone got any idels?
Old Sep 2, 2008 | 11:44 PM
evonsti's Avatar
its a 04 evo 8
Old Sep 2, 2008 | 11:47 PM
tephra's Avatar
First thing - did you keep a copy of the original stock map? if so go and make sure the immobiliser code is in there if so - email it to yourself and write it down on a piece of paper..
Now when you say it doesn't start - does it kick over? or nothing?
Old Sep 2, 2008 | 11:54 PM
evonsti's Avatar
well it does crank tun over pefect but na i dont have the stock my i copy any more i lost it.. do i need the immobilser code how can i get it?
Old Sep 3, 2008 | 12:08 AM
EVOIXMR8916's Avatar
ok same thing happened to me a my bad battery was the culpret resulting in a low volt short that shorted out my ecu and immobilizer....it was a 2500 mitsubishi warranty claim and i was lucky with my mitsu dealership....goodluck....
Old Sep 3, 2008 | 12:32 AM
tephra's Avatar
if you have lost the immobiliser code then you are in for problems..
there are ways around it - just search and ye shall find...
Old Sep 3, 2008 | 07:24 AM
Chabada15's Avatar
you will have to modify your rom to disable the immobilizer, good luck.... you really should have saved the stock rom
truthdweller
2057
Oct 22, 2021 04:09 PM
evoscan
52
Jun 20, 2017 01:46 AM
Xene
Jun 1, 2016 07:20 AM
Mike Barczynski
Jan 10, 2016 05:06 PM
llabmik2
Feb 7, 2007 11:05 PM
