It's alive! (Speed density, stock ECU)
Old Sep 7, 2008 | 07:42 PM
  #31
justboosted02's Avatar
Originally Posted by Jack_of_Trades
You don't think we can get around that? I certainly do.
Mitsu was damn good with their knock system, the reason no one has really bothered to mess with it is because its very well dialed in from the factory. Maybe one or two adjusts is all anyone would ever need really.
its dialed well from the factory for the factory engine
not everyone has a factory engine
Old Sep 7, 2008 | 07:52 PM
  #32
pjb00stin's Avatar
nice
Old Sep 7, 2008 | 11:28 PM
  #33
oldevodude's Avatar
Kind of ironic really In the mustang 5.0 world people convert speed density to maf based systems and in the Evo world we are speaking of maf to speed density. No point really just a thought put to post
Old Sep 8, 2008 | 08:14 AM
  #34
l2r99gst's Avatar
They are probably converting to hot wire maf systems, though, not Karmen maf systems.
Old Sep 8, 2008 | 08:24 AM
  #35
tkklemann's Avatar
What the heck is going on with that TB? I see your IAC is mounted on the top... Hmmm, wuzzup wif dat?
Old Sep 8, 2008 | 11:16 AM
  #36
Tuner@Swift's Avatar
Its a BBK 75mm Mustang 5.0 TB. The only way I could get it to work with the intake manifold was to flip it upside down.
Old Sep 8, 2008 | 11:25 AM
  #37
tkklemann's Avatar
Did you make the IAC housing? Or where did you get it?
Old Sep 8, 2008 | 11:33 AM
  #38
It came with the IAC housing. I had to modify the stock throttle wheel to fit and make an adapter plate for the TPS sensor.
Old Sep 8, 2008 | 11:36 AM
  #39
sabastian458's Avatar
Originally Posted by tephra
depending how sucessful it is, and if Bez doesn't mind - I might integrate into the next release...
very interested as I already have the JDM map, and a AEM temp sensor installed in the car. (temp sensor was made into my UICP from the prior owner runing an AEM)
Old Sep 8, 2008 | 05:09 PM
  #40
cssaddictm4's Avatar
How was the rom patched?
Old Sep 9, 2008 | 12:06 PM
  #41
tuning g's Avatar
no xml and start up cal yet max you guys are not paving the way your re-writing it how it should be
Old Sep 9, 2008 | 12:11 PM
  #42
any update on making this work for Evo 8 roms?
Old Sep 9, 2008 | 12:58 PM
  #43
Jack_of_Trades's Avatar
What are some IAT sensors we should look into getting? I heard the AEM IAT Sensor is good because of the plastic tip resists heat soaking the sensor more.
Found it for $52 shipped HERE.
Old Sep 9, 2008 | 01:09 PM
  #44
evofool's Avatar
this sounds like a good winter project, i imagine the kinks will be worked out by then
Old Sep 15, 2008 | 11:57 PM
  #45
draconx's Avatar
hey can you give us details on this? i would like to know how to do i on my evo 8 xx15. thx
