ACD and ABS flashing
Old Sep 8, 2008 | 09:10 AM
RyeLou's Avatar
I just got my cable. I know I've read about the ACD lights flashing before, but I figured I'd check to make sure mine is still normal.
When I first had it plugged in the Tarmac setting (which I was in) was flashing as well as the ABS light. Once I got above 10 mph, the ABS went off and the ACD was solid like normal. Slowing down below 10mph and the ACD started flashing again. I logged one run and afterwards all of the ACD lights were flashing. I unplugged the cable and everything went back to normal.
Normal?
Old Sep 8, 2008 | 11:54 AM
RyeLou's Avatar
https://www.evolutionm.net/forums/sh...light=flashing
According to that it seems normal. As long as it isn't hurting anything I won't be pulling the pin.
Old Nov 22, 2009 | 02:55 PM
MR White's Avatar
Which pin are you supposed to pull? I just got my tactrix cable and my ABS and ACD light flashes when connected to car.
Old Nov 22, 2009 | 03:17 PM
alicea8541's Avatar
That is normal for a Tactrix 1.3U cable.
Old Nov 23, 2009 | 08:42 AM
fostytou's Avatar
EvoM Community Team
This is normal, as all of the other threads on this topic say, you can disable the flashing lights in the evoscan menu.
Old Nov 23, 2009 | 09:43 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
This is normal don't worry about it
Old Nov 23, 2009 | 09:57 AM
tnt1106's Avatar
That feature never worked for me. My lights been flashing since May 08, never been an issue other than distracting under 15 mph.
Old Jan 6, 2010 | 05:22 AM
MR White's Avatar
Is this where you disable in evoscan? Also can anyone post a pic of the 9th pin?
killerpenguin21
Jul 11, 2018 10:41 PM
BuiltS13
18
May 23, 2016 08:04 AM
CantWaitToBoost
Aug 13, 2011 03:50 PM
blackdemon
16
Nov 2, 2009 12:07 PM
Profoxcg
Oct 27, 2007 10:31 AM
