2 step question
Old Sep 21, 2008 | 03:33 PM
jmtx86's Avatar
2 step question
Since im seeing some knock on the 2 step would the ecu switch over too the low octane map?
And load percentage does the motor usually see?
Old Sep 21, 2008 | 04:14 PM
dolphin888's Avatar
It's normal to have knock, when 2step rev limiter is activated ECU will not switch to the low octane map, as far as I know..
Old Sep 21, 2008 | 04:22 PM
tephra's Avatar
depends on how much knock... Log "Octane Number/Value" to see how much of the low oct maps its using...
dont understand your second Q
Old Sep 21, 2008 | 05:51 PM
jmtx86's Avatar
I want to set a certain amount of timing for my 2 steps so i need to know what boxes to change
Old Sep 21, 2008 | 05:52 PM
kreionic's Avatar
log your 2 step and see what load its at
Old Sep 23, 2008 | 07:02 AM
jmtx86's Avatar
OK i logged it and set timing to -15, making 15 psi off the 2 step
Old Sep 23, 2008 | 01:08 PM
TouringBubble's Avatar
-15 is WAY too much, but aside from that the ECU won't pull that much timing anyway. The IX is limited to -10 and the VIII is limited to -8 or something I think.
To get 15 psi on the 2 step you can run +6º or so ... no need to pull that much. I get knock anywhere above 13 psi or so anyway.
chmodlf
Feb 15, 2010 04:36 PM
fknlowpsi
14
Nov 13, 2007 12:43 PM
SPOOLEDTSiAWD
Oct 15, 2007 10:24 PM
ant_turbo
Sep 25, 2006 03:08 PM
htsai14752
Jul 22, 2004 02:35 PM
