rich afr's during spool
Old Oct 16, 2008 | 10:39 PM
RoadSpike's Avatar
Originally Posted by sharkm87
bump for help......put back map with ls enabled.....still same issue......i know with the evo 8, and the new xml code, it added quite a few extra ls options....should one of these be altered?? i can not figure out the rich spool afr's
I think its time to start simple and do a boost leak check make sure everything is tight. I had wild AFR's at one point ended up being the MAF tube being loose
Old Oct 17, 2008 | 04:21 AM
sharkm87's Avatar
did boost leak test..got no hissing or anything..sprayed down all pipes...no bubbles or nothing....i did actually clean my maf and air filter yesterday..haven't ran it yet to see if anything changed.
Old Oct 17, 2008 | 10:42 AM
sharkm87's Avatar
bump
Old Oct 17, 2008 | 10:49 AM
RoadSpike's Avatar
Want to send me your rom? I could take a look at it for anything obvious
TJung
Jun 17, 2011 07:04 AM
crimson red
14
Apr 29, 2011 01:36 AM
Jim in Tucson
Mar 1, 2010 12:24 PM
RoadSpike
Sep 30, 2007 05:42 AM
vroomevo
16
Jul 26, 2007 07:03 AM
