Speed Density Implementation Discussion
Old Dec 21, 2008 | 07:53 PM
  #166
tephra's Avatar
at the moment I am concentrating on getting V6 out, then I will resume work on SD.
Old Dec 21, 2008 | 07:57 PM
  #167
evo8dad's Avatar
Thx for the update. Let me know if you need any testers as I usually have an array of Evos around the shop, although I have a perfect mix now ;-)
Old Dec 22, 2008 | 04:46 PM
  #168
Cyloc's Avatar
definately a mod I am looking foward to
Old Jan 12, 2009 | 04:02 PM
  #169
Cyloc's Avatar
If a person has the voltage table for am AEM(or other brand) 5 bar would you be able to input the voltage numbers for that sensor? Just a thought I had. Some of the guys that want to run higher boost may benefit from that. I know after I redo some stuff in my motor, I will be trying to push 40 psi.
Old Jan 12, 2009 | 04:19 PM
  #170
tephra's Avatar
yeah as long as the sensor is linear in its output then you can have whatever you like...
Old Jan 12, 2009 | 04:47 PM
  #171
RoadSpike's Avatar
I got my 5bar working for a zeitronix sensor on the ECU as it is right now no CEL's even. I'm pretty sure the AEM 5 bar is going to be very similiar far as checks go.
Old Jan 12, 2009 | 04:51 PM
  #172
Cyloc's Avatar
Good to know. I can get my hands on the zeitronix one really easy.
Old Jan 12, 2009 | 05:57 PM
  #173
RoadSpike's Avatar
Just find a voltage spec sheet on the AEM unit.
All we need to know is a few simple parameters
Zeitronix 5BAR:
0BAR is 0.5v
5BAR is 4.5v
If your unit is linear with the voltage spacing like mine then my settings will work out perfectly for you.
Old Apr 25, 2010 | 10:21 AM
  #174
eyebrowski's Avatar
Can the IAT and MAP sensors share the same ground wire to the ECU?
Old Apr 25, 2010 | 09:29 PM
  #175
mrfred's Avatar
Originally Posted by 0xDEAD
Yes and it would be preffered as they are both low level "signal" grounds. Use "dirty" grounds for things like the solenoids and higher current devices that aren't sensitive to ground loop issues. Dirty ---->chassis ground.
Thermistor temperature sensors are actually not very sensitive to ground location. No problem to ground the IAT sensor in any reasonably good location. I grounded mine on the IM.
tunermt
Cobb AccessPORT
20
Jul 30, 2020 10:38 PM
jars121
Mar 12, 2017 08:10 PM
iowa_guy
Sep 21, 2011 02:32 PM
utripin
Feb 24, 2010 03:35 PM
l2r99gst
Mar 23, 2008 01:16 AM
