P0105 MAP Circuit Malfunction
Old Nov 8, 2008 | 09:00 PM
evl08's Avatar
The service engine light has been on for over a week now It first appeared just after starting the car and went to drive out of a car park. It felt like it bogged down more than usual and then bam the light came on. I used scan tech to pull the code and got:
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
I didn't even realise the EDM VIII had a MAP sensor... i've been trying to find a VIII 260 workshop manual, but haven't had much luck.
I have checked the continuity of the wiring from the MAF to the ECU and also what I am guessing is the MAP sensor to ECU.
I searched and couldn't find any info on this code...any help is appreciated
Old Nov 8, 2008 | 09:04 PM
evoredy's Avatar
Attachment 125598
thats the BCS solenoid!
Old Nov 8, 2008 | 11:34 PM
evl08's Avatar
hehe...I really was just guessing! OK, so the MAF and BCS wiring is fine. Now where do I find the MAP/barometric sensor/circuit?
Old Nov 8, 2008 | 11:45 PM
evoredy's Avatar
top of the intake manifold. it looks like the sensor pictured in the SpeedElement group buy #3 thread on this or earlier page. 2bolts holding it on to the manifold. you'll spot it right away.
good luck.
Old Nov 8, 2008 | 11:49 PM
evoredy's Avatar
i bumped the thread lol. its up top now.
Old Nov 9, 2008 | 12:16 AM
evl08's Avatar
The EDM VIII model doesn't have that location on the intake manifold used...where else could it be??
Old Nov 9, 2008 | 12:47 AM
evoredy's Avatar
Attachment 125615
sorry, i don't know! does the code keep coming back?
anyone else?
EDIT: maybe the MAF went bad???
EDIT2: damn..i knew this..the baro is in the maf. lol. its probably bad if your continuity checks are good.
Old Nov 9, 2008 | 01:40 AM
evl08's Avatar
Yeah, the code comes back after I clear it.
I found a manual, only it's not really detailed enough and doesn't mention the baro sensor.
The sensor I pointed out appears to be a wstegate solenoid valve
Old Nov 9, 2008 | 02:03 AM
RazorLab's Avatar
Baro sensor is in the MAF.
evohq
Feb 21, 2016 06:49 AM
fwd_josh
Jan 23, 2010 09:54 AM
Danieln
Dec 12, 2009 03:00 PM
BadazzCR
Aug 23, 2008 07:40 AM
onboost
Jun 22, 2007 02:41 PM
