help reading rom
Old Nov 23, 2008, 01:21 AM
infini_IV's Avatar
Originally Posted by grayw
None of the attached files are that size unzipped. Can you email it?
yep can do whats your email address?
Old Nov 23, 2008, 01:27 AM
grayw's Avatar
Check your PM's.
Old Nov 23, 2008, 01:50 AM
grayw's Avatar
Thats the correct XML file I've posted, you should just save it in the directory shown, then open the rom.
Old Nov 23, 2008, 10:04 PM
infini_IV's Avatar
no matter what i do i cant open any files there is just nothing there
Old Nov 23, 2008, 10:31 PM
Deepnine's Avatar
you can't find your rom file?
rename it to something.hex oder something.bin
without hex or bin ending, ecuflash can't find the files.
Old Nov 23, 2008, 10:47 PM
infini_IV's Avatar
ok the file that was posted as the right file is an xml file which ecuflash wont find. however when i open evoscan there is some .hex files in there that ecuflash will read so ive established what the problem is (need hex files instead of xml) now i need the 98600414 rom in a hex format can anyone help?
Old Nov 23, 2008, 11:11 PM
Deepnine's Avatar
have you copied the 98640014.xml to the C:\Program files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo directory?
You don't need to open or find any xml, thats automatic. just open your rom file (hex or bin). Or connect to ecu and read again.
It works for me with your posted files. I just had to rename them to oem.hex
Old Nov 23, 2008, 11:38 PM
infini_IV's Avatar
yes i have tried this on my laptop it will now see the file when i click the open rom but when i click the file it says ecuflash can not recognize this rom image............ again i just cant figure out what ineed to do to be able to edit functions
Old Nov 24, 2008, 12:10 AM
infini_IV's Avatar
when i open the C:\Program files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo directory manually by typing it in the address bar there is a whole lot of files that are xml files however if i open ecflash and click open then look in Program files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo there is nothing there???????
Old Nov 24, 2008, 12:49 AM
Deepnine's Avatar
no, you dont need to open the xml files in Program files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
that is NOT the rom
the rom is the file you posted first. open this file.
Old Nov 24, 2008, 12:52 AM
Deepnine's Avatar
take this two files.
1st: COPY the 98640014.xml
2nd: OPEN the 98640014.rom
File Type: zip
Old Nov 25, 2008, 06:25 AM
fixem2's Avatar
Another option is to copy the XML file to the correct folder. Then go out to your car and open EcuFlash and read the ROM from the ECU directly. Does this work? If so, then save the ROM to somewhere you will find again.
Old Dec 9, 2008, 11:13 PM
infini_IV's Avatar
any other ideas im still trying to do this?
Old Dec 9, 2008, 11:19 PM
infini_IV's Avatar
when i save this to my desktop i then extract it and all thats inside it is 1 file thats named 98640014 and my computer doesnt know what file type it is but does know that its 95.3 KB in size what do i do with this?????
Old Dec 13, 2008, 12:21 PM
infini_IV's Avatar
anyone?????? please see my first post im offering a paypal payment to anyone that can help me fix this
Quick Reply: help reading rom
