The definitive EcuFlash Evo 10 thread
Old Jan 2, 2009 | 10:53 PM
  #181
nj1266's Avatar
Originally Posted by HB Speed
And it wasn't released to RIcer X1, by colby.
Ecuflash 1.41 isnt public yet because of these issues.
Ricer happen to get a copy and has proceeded to brick his ecu and give it out to more people who have in turn bricked more ecu.....
What dont you get?
I think what Ricer did was a blessing in disguise. Imagine if the software was released and Colby did not know about the glitch that made ordinary users brick their ECUs. Things would have been much worse and there would have been 100s of bricked ECUs rather than 2 or 3.
I for one would not flash my ECU with a beta software, but Ricer did it and took the responsibility for it. It turned out to be a good thing for the community (bad for him, though), since now we know that there is an issue with flashing the X MR with the software.
Old Jan 2, 2009 | 10:58 PM
  #182
HB Speed's Avatar
We already knew about that bug though....
Old Jan 2, 2009 | 11:02 PM
  #183
RicerX1's Avatar
Yea they did. There was already a bricked JDM SST ecu before mine.
Old Jan 3, 2009 | 12:00 AM
  #184
GST Motorsports's Avatar
It doesn't help that you (who shouldn't have had it anyway) keep giving it out to unqualified people that in turn brick more Ecu's......
Can we put these type of posts in a new thread and not noise up a informative thread?
It's not a issue with the MR ECU from what I have seen.
Old Jan 5, 2009 | 03:07 PM
  #185
aiden1983's Avatar
I just wanted to know what cable and adapters I need to be able to tune? I see that there are a few things avalible but not sure which I should get. Please let me know which I should get from here: http://www.tactrix.com/index.php?cPath=24_48.
Anything else I need? Oh and the MR will use the same steps as tuning the GSR correct?
Old Jan 5, 2009 | 03:08 PM
  #186
aiden1983's Avatar
^^^oh and does any of our vendors sell this stuff?
Old Jan 5, 2009 | 03:41 PM
  #187
Rguy's Avatar
All you need for the X is the openport 2.0 $169 kit. Buy it from tactrix!
The MR will have the same steps as far as tuning goes but of course will have different maps that the GSR doesnt.
Old Jan 5, 2009 | 05:51 PM
  #188
aiden1983's Avatar
I don't need all the adapters? Should I get the WB from them?
Old Jan 5, 2009 | 06:54 PM
  #189
Rguy's Avatar
No for the X you do not need the adapters. Cable and openport plug only are needed.
Get the WB from anywhere you want, thats totally up to you.
Old Jan 6, 2009 | 05:13 PM
  #190
Bob_tm's Avatar
What is the "Open Loop Throttle #1" map and how it used?
rpm - ThrottleVoltage
500 - 2.18
1000 - 2.30
1500 - 2.79
2000 - 3.75
2500 - 3.12
3000 - 3.12
3500 - 2.81
4000 - 1.87
4250 - 1.72
4500 - 1.56
4750 - 1.37
5000 - 1.25
5250 - 0
8000 - 0
Old Jan 7, 2009 | 10:49 AM
  #191
Colin's Avatar
It is max TPS voltage at given RPMs that allows running Closed Loop.
You can see that there is no OL at 5250 rpm allowed.
500 - 2.18
1000 - 2.30
1500 - 2.79
2000 - 3.75
2500 - 3.12
3000 - 3.12
3500 - 2.81
4000 - 1.87
4250 - 1.72
4500 - 1.56
4750 - 1.37
5000 - 1.25
5250 - 0
8000 - 0
Old Jan 7, 2009 | 04:17 PM
  #192
gunzo's Avatar
Originally Posted by Colin
It is max TPS voltage at given RPMs that allows running Open Loop.
Its the other way round .. the max TPS allowed to run under closed loop .. beyond that voltage, the ECU transitions to openloop ..
from 5250rpm onwards the car ONLY runs in open loop
Normally not touched, but if you want to run openloop most/all the time this table and open loop load tables are the tables to change ..
Old Jan 7, 2009 | 07:05 PM
  #193
downforceinc's Avatar
Wow this is an interesting thread....good work on ECUFlash
Old Jan 7, 2009 | 07:19 PM
  #194
xbox4414's Avatar
So how do u tune that table to run open loop all the time? Set the values to 0?
Old Jan 8, 2009 | 09:40 AM
  #195
Colin's Avatar
My mistake - should be max TPS voltage that allows running closed loop.
If you want to run all the time open loop set all values to 0.
