The definitive EcuFlash Evo 10 thread
It definitely is amazing progress gunzo. I know we all appreciate everyone working on the project.
People are just so excited for the product that it eats away at them and they start to focus on it way too much.
Any estimated timelines for a full launch? February maybe?
So until someone with a USDM car start fiddling with the ROM .. its going to wait ..
.. how badly you need this done ?? does this allow running of testpipes too ??
I wouldn't mind eliminating that secondary o2 sensor CEL either... this will allow the running of testpipes without throwing the CEL, which would be great... to answer your question.
It's not a huge deal. Just saw that you were able to do this on the older EVO's so figured it would eventually be possible on the X. Considering the price and how well it works, I'm not complaining.
So there is no map you change and just use your WB 02 to set the closed loop setting? I was reading that 15.2 is better for MPG in this thread: https://www.evolutionm.net/forums/ec...-tune-evo.html
So why try to tune to 15.2 if you can't? Am I missing something?
I'll start after new year
If I manage to solve it .. please give thanks to MJ and MrFred
So you are saying the stock NB controls the AFR in closed loop vs the ECU in open loop? I just want to be clear then, the ECU does not control AFR in closed loop. So the NB O2 is demanding the 14.7?
I would THINK the NB is checking for 14.7 and the ECU is requesting the 14.7. But what ever. Ya I would just like to find a better way to control the cursing AFR to get better MPG.
The target AFR for closed loop is 14.7:1. This is built into the engine control code. The ECU uses the stock NB O2 signal to determine how close the AFR is to the target value and (the ECU) makes fuel trim adjustments (injector pulse width adjustments) to maintain 14.7:1 as air temperature, humidity, elevation, engine temperature, etc change.
So, NB O2 sensor is simply a tool used by the ECU, and its the ECU that does the controlling.
Using a simulated NB O2 signal from a WB setup to achieve leaner AFRs than 14.7:1 during closed loop is a simple and reasonably effective way to get leaner closed loop cruise.
