The definitive EcuFlash Evo 10 thread
Remember this is a whole new motor with different tuning strategies than the 4G63. If you try to tune it like you know a 4G63 should be tuned you won't make any power.
They take a bit more timing then our beloved 4G63s.Using PCMscan for logging for now.
The AEM intake has a larger Maf housing so it screws with the MAF a bit and the car actually sees lower loads than with the stock Maf housing, one of the big reasons the intake leans the car out so much.
It's actually not too bad up top for a stock car that drops to 13psi or so.
What parameters can you log with PCMscan?
Currently the only loggers that can log knock on the X is EcuTeks logger and Cobb Tunings logger.
Yup and yes I have seen knock on untuned cars with mods, even 100% stock 10's, the usual.
Looking at them i am somewhat confused (godilovecablethrottles). what is the z axis? is it % of what you give the pedal. So if the map is 60% does that mean it will open the throttle by 60% of what the pedal is at? I know the STi will give greater throttle then what the pedal is at which feels a tad weird. So at part throttle it might give 10% more to make the car feel "peppier". Do you know if you can go over 100% in those cells?
You truely do not need something that can log knock. If you follow the timing charts and then you see it jump down closer to the lower timing table.... you know it knocked. That is how mitsu has always did their knock acknowledgment by dropping timing.
Its better to be able to log knock.
That is true but it's a little old school for the EvoX. There are other factors that can cause the EvoX ECU to pull timing besides knock.
Thats how the subaru guys tune. It is a very archaic way of determining knock and if it pulls 1-2 degrees it may be interpolation. you also don't really know the severity of the knock.
Well, yes. Of course, it is better to see exactly how much knock there is. I was just saying that by the use of interpolation you can SEE in the timing curve if it knocked or not and it is very possible to tune that way. And since evoscan isn't out yet and if you don't have access to the ecutek or cobb loggers you have no other way.
