The definitive EcuFlash Evo 10 thread
Old Jul 1, 2009 | 06:59 AM
  #526
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Now I understand X code enough to make inspection bits patch as in CT9A if there is enough interest and some volunteer to test it
Old Jul 1, 2009 | 07:34 AM
  #527
LaXGSR's Avatar
It would be really cool if you could disable the rear o2 CEL. Specifically, both the sensor in the downpipe before the cat, and the sensor in the cat. My guess is the combination of these two are used to trigger the rear o2 CEL. This would allow using a wideband in the stock downpipe (before the cat) in place of the stock o2 sensor without triggering a CEL
Old Jul 1, 2009 | 09:18 AM
  #528
mrfred's Avatar
The first sensor is for closed loop AFR control (during cruise conditions). Its only the one in the cat that needs to be disabled.
Old Jul 1, 2009 | 10:53 AM
  #529
Bob_tm's Avatar
- disable the rear o2 CEL. Can test on edm evo
Old Jul 1, 2009 | 11:57 AM
  #530
LaXGSR's Avatar
mrfred, when you say first sensor, do you mean the upstream o2? The evo x has 3 sensors. One upstream, one in the downpipe before the cat, and one in the cat section itself. This is nice because the middle o2 sensor in the downpipe can be replaced with a wideband for logging purposes (pre-cat).
Old Jul 1, 2009 | 12:54 PM
  #531
mrfred's Avatar
ok, I get it now. There are references in the FSM to an offset O2 sensor value. I always thought this was some sort of reference voltage built into the post-cat O2 sensor, but it must be the O2 sensor just before the cat. They must use this as a precat reference value. (They use the 1st O2 sensor for this in the Evo 7/8/9.) Thanks. This is helpful in understanding the disassem.
Old Jul 1, 2009 | 01:37 PM
  #532
GST Motorsports's Avatar
Three? Since when?
- Bryan
Old Jul 1, 2009 | 02:15 PM
  #533
xPRimNT's Avatar
Double post fail.
Old Jul 1, 2009 | 02:16 PM
  #534
xPRimNT's Avatar
Hmm.
I thought there were only two, pre and post cat. This is news to me, and none of the OBD scans indicate more than two... Though I haven't seen them physically (except for the rear one)
Are you sure?
Old Jul 1, 2009 | 02:24 PM
  #535
LaXGSR's Avatar
Oops, maybe I'm confused then - I thought there was an o2 sensor upstream before the turbo? There are definitely two post-turbo (one in the downpipe, one in the cat), but is there none upstream from that?
EDIT: Yup, I'm wrong. Sorry for the confusion. I've never had a car that had an upstream (front) o2 sensor so far back. I always assumed there was another upstream sensor somewhere in the engine bay.
Old Jul 1, 2009 | 04:40 PM
  #536
tephra's Avatar
there is only 2
that offset is the voltage offset u see in the code mrfred!
you can do a rear02 disable by flipping bit6 of ecu-options-2 (ie second last bit)
you will have to remove the sensor thou, as its heated and once you flip that bit it disables the heater...
Old Jul 2, 2009 | 09:58 AM
  #537
ralliart91's Avatar
Originally Posted by tephra
there is only 2
Hi Tephra,
Can you confirm this solution for the X ?
If no : you know how to for the X ?
Thank's
Patrick
Old Jul 2, 2009 | 04:25 PM
  #538
tephra's Avatar
if you send me a front pipe I can test it out
atm my car is stock so I dont get an exhaust cel's hehe
ill be testing the removal of the rear02 over the weekend - i need to install a wb into that hole
Old Jul 4, 2009 | 03:18 PM
  #539
otbEVO's Avatar
Very interested in the rear o2 disabling. Keep us posted tephra!
Old Jul 12, 2009 | 12:17 PM
  #540
HB Speed's Avatar
USDM removal of rear o2 and install of a Wideband works fine!
killed it via options #2 no cel
