The definitive EcuFlash Evo 10 thread
Old Mar 1, 2009 | 04:27 PM
  #376
zTargeTz's Avatar
Originally Posted by onboost
evoscan shuldnt be too far away. the developer has a X ecu but needs my ETACs ecu so he can communicate with it. I need my car this week but i will be sending him my ETACs next monday.
Hopefully shuldnt be too far away after that.
im pretty sure i am the only person with a X in New Zealand that uses these forums so im the only person he can get an ecu off at short notice.
im doing my best
I definatly apreciate it, he's a huge asset to this community
can't wait for evoscan
Old Mar 1, 2009 | 10:39 PM
  #377
NZEvox's Avatar
im doing my best
maybe Not the only Kiwi
Old Mar 2, 2009 | 05:52 AM
  #378
murlo26's Avatar
well perhaps the fact that the exhaust scaling is off is why my tuner was only able to hurt power by adjusting exhaust mivec. It is all becoming clear now.
Old Mar 2, 2009 | 12:34 PM
  #379
zTargeTz's Avatar
set the MIVEC exhaust side to 0 from 4,000 - redline
seems to be the best for power from what i've read.
Old Mar 2, 2009 | 01:52 PM
  #380
burnings's Avatar
Across the loads as well?
Old Mar 2, 2009 | 05:49 PM
  #381
mrfred's Avatar
Originally Posted by burnings
Seems that ECUflash does not read the xml when it loads up the rom. How to force it to reload the parameters from the evo10base.xml?
The xml file needs to be opened using a text editor such as Notepad which is included with Windows. The xml files are located here:
\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
Open the file, insert the changes, save it, and then relaunch ECUFlash.
Old Mar 2, 2009 | 08:46 PM
  #382
zTargeTz's Avatar
I would assume just the higher load cells, you can play around with the lower cells and find more torque, really widen out the band
this is all just what I've gathered from reading other peoples roms and this forum, I just got my cable in the mail today.
XML is beautiful to work with
Old Mar 2, 2009 | 10:11 PM
  #383
DB Performance's Avatar
Maybe an intake/MAF scaling table? I don't have an Evo X here to test it on, just a guess. I broke the table into 2, because it is so big. Somewhat similar to MAF scaling table on a hotwire Subaru.
<scaling name="MAFVoltScaling" units="units" toexpr="x*5/1024" frexpr="x*1024/5" format="%.3f" min="0" max="255" inc="1" storagetype="uint16" endian="big"/>
<table name="MAF Comp Test 1" category="Intake" address="5753a" type="2D" level="1" scaling="uint16">
<table name="Volts" address="615ea" type="X Axis" elements="69" scaling="MAFVoltScaling"/>
</table>
<table name="MAF Comp Test 2" category="Intake" address="575c4" type="2D" level="1" scaling="uint16">
<table name="Volts" address="61674" type="X Axis" elements="61" scaling="MAFVoltScaling/>
</table>
Old Mar 3, 2009 | 05:31 PM
  #384
Deepseadiver's Avatar
I'm still waiting on my cable...... It's been months now!
Old Mar 4, 2009 | 12:33 AM
  #385
zTargeTz's Avatar
might want to email them, i got mine with in 4 days of payin for it
Old Mar 4, 2009 | 06:37 AM
  #386
burnings's Avatar
Thanks!, I realised that I gotta make the changes in ECUflash as well.
Btw, may I know on a EBC setup, can I upped the reactive boost and passive boost all the way up?
Old Mar 4, 2009 | 07:27 AM
  #387
aiden1983's Avatar
Why not just use the JDM MIVEC maps? I hear they are pretty close to optimal.
Old Mar 4, 2009 | 11:44 AM
  #388
GST Motorsports's Avatar
Not at all.
Old Mar 5, 2009 | 07:04 AM
  #389
mrfred's Avatar
If you mean a standalone EBC setting, then the reactive and passive boost values have no effect except the BDEL. In order to prevent a high boost CEL, the BDEL needs to be adjusted to track the load achieved using the EBC.
Old Mar 5, 2009 | 07:55 AM
  #390
Noize's Avatar
EvoM Administrator
Got another X. I logged onto the Tactrix store and saw they had an ECU recovery service. That's spooky. Are a lot of people still bricking ECUs?
I'd go EcuTeK again, it was stable and I loved it.
I'm not worried about logging, I have my old/existing maps to work with.
I am worried about:
1) Stability
2) All maps I need being there
3) Interface being as good or same as EcuTeK this time around.
I prefer EcuTeK stability, but I want the ability to flash my own car without traveling to the shop.
