The definitive EcuFlash Evo 10 thread
Old Jan 30, 2010 | 05:53 PM
  #586
omni-star's Avatar
Terribly sorry to cloud this thread. Didn't know if it would be easier to open a ticket or talk with some of you guys. I have the latest version of ECUflash downloaded, but it doesn't seem to be working properly. The drivers have been installed and I do have the correct tactrix openport cable. When I open ecuflash, several icons aren't highlighted. To be exact, the only icon that is highlighted is the "Open ROM" folder under File. If I click on ECU, none of the options are highlighted here either.
If anyone has any guidance and can point me in the right direction, that would be greatly appreciated.
Old Jan 30, 2010 | 07:30 PM
  #587
xPRimNT's Avatar
^ Try plugging in the OP to your car first. Read your ROM, etc.
You'll have many more options enabled
Old Jan 31, 2010 | 08:58 PM
  #588
Brady 154's Avatar
Map ???
I am curious if there are maps available online for my 09 Evo X MR or if it has to be custom mapped at a shop. I am really interested in getting rid of the turbo lag. I have already bought the Tactrix cable and downloaded my stock ".hex" map file.
Brady
Old Jan 31, 2010 | 10:40 PM
  #589
mrfred's Avatar
Brady
If you're in Washington State, give English Racing a call. They can set you up with a base map or a custom tune.
Old Feb 3, 2010 | 06:08 AM
  #590
Brady 154's Avatar
Map ???
I am actually in Houston now. Any ideas on who to see here?
Old Feb 7, 2010 | 06:03 PM
  #591
nj1266's Avatar
Anyone has a complete 2009 Ralliart definition file? Mine is not complete. It does not show the MUT table nor does it show the Reactive Solenoid WGDC Correction table.
Old Feb 7, 2010 | 08:08 PM
  #592
SiC's Avatar
SiC
3efc0 for the MUT table and 58d20 for Reactive Solenoid Boost Correction with a table address of 6261a.
Old Feb 7, 2010 | 08:16 PM
  #593
nj1266's Avatar
Thanks SiC, I will try that.
Old Feb 7, 2010 | 08:21 PM
  #594
nj1266's Avatar
The Reactive Solenoid WGDC Correction Interval does not have a table address. I am looking for these two for the 09 RA. Are these correct?
<table name="Reactive Solenoid WGDC Correction Interval (High Gear Range)" address="5346a"/>
<table name="Reactive Solenoid WGDC Correction Interval (Low Gear Range)" address="546b2"/>
Old Feb 7, 2010 | 09:13 PM
  #595
GST Motorsports's Avatar
These are correct:
<table name="Reactive Solenoid WGDC Correction Interval (High Gear Range)" address="54696"/>
<table name="Reactive Solenoid WGDC Correction Interval (Low Gear Range)" address="5346a"/>
Old Feb 10, 2010 | 11:09 AM
  #596
Kasander's Avatar
Does someone got the adress for the MAF Scaling table for the RA 09 (53600010)?
I've tried one that should work with almost all rom but the value I get are not right, there's no scale in what I see hehe it's a bumpy stuff.
Only the 3rd portion of the table have not really weird value.
Thanks
Old Feb 10, 2010 | 02:59 PM
  #597
Thanks
here you go:
<table name="MAF Scaling Part 1" address="57586">
<table name="Volts" address="6164a"/>
</table>
<table name="MAF Scaling Part 2" address="575de">
<table name="Volts" address="616a2"/>
</table>
<table name="MAF Scaling Part 3" address="57636">
<table name="Volts" address="616fa"/>
</table>
- Bryan
Old Feb 10, 2010 | 04:45 PM
  #598
Kasander's Avatar
Thank you very much.
Old Feb 14, 2010 | 05:18 PM
  #599
nj1266's Avatar
Originally Posted by GST Motorsports
These are correct:
Thank you my friend
Old Feb 14, 2010 | 06:48 PM
  #600
Kasander's Avatar
Well, I'm back again with a question. I just don't wanna **** anybody off but I'm trying my best to search the data without good results. Since there's no real standard in how the info is posted, it's hard to figure a really good way to get them some refer the rom as GSR 2010, GSR '10 or the ROM ID.
Since I'm doing the jump from my RA '09 to a GSR 2010 next week, I'm trying to find the same definition I'm used to work with on my RA.
For ROM ID 55570005, I'm missing:
Stopping LTFT from affecting WOT
MAF Scaling
Thank you.
