The definitive EcuFlash Evo 10 thread
Old Jun 13, 2010 | 02:27 PM
  #616
yorT's Avatar
Okay, appreciate it. I'm thinking they may have not hooked something up properly after changing out the master cylinder and I don't think they bleed the brake line either.
Old Jun 15, 2010 | 09:02 PM
  #617
thevidon's Avatar
Originally Posted by SiC
PM'd
Why would you PM this info? I am looking for the same thing - maybe a quick writeup in the thread would be in order?
I have placed an order for an OP 2.0 from Tactrix, but have no idea if I need additional cables (does my OP 2.0 order come with everything I need?), or how everything is supposed to work in general. For someone coming in fresh to this process there is almost no information readily available to explain the dummy newb questions.
Can Macs be used - looks like its v1.38 only for OSX? Is it just a different version number from the PC version but still workable?
Thanks!
Old Jun 15, 2010 | 10:13 PM
  #618
SiC's Avatar
SiC
Because it was off topic and the information was not positive. Later found out that the original unbricking method did not work so you dont need a breakout box. Search other threads on this site for unbricking ECUs, there should be at least 2.
Old Jun 16, 2010 | 08:08 AM
  #619
CatalystGod's Avatar
Thanks!
are you looking for something like this?
https://www.evolutionm.net/forums/ev...tructions.html
Old Jun 20, 2010 | 03:37 PM
  #620
thevidon's Avatar
So the Mac OS-X version of ECUflash is different from the PC one. Will the OSX version work for Evo X's?
Edit - nevermind Evoscan wont work on Macs anyways.
Old Jun 21, 2010 | 10:39 AM
  #621
D-VO's Avatar
Hey guys. I apologize in advance for asking a question that was already probably answered, but I'm not sure if I've found a definitive answer. Are the only EVOX ecu's bricked due to the beta version ECUFlash 1.41? Or are there still bricking issues?
Old Jun 21, 2010 | 02:39 PM
  #622
Golden's Avatar
I've been using 1.43.3000 without any issues.
Old Jul 6, 2010 | 03:36 PM
  #623
Mag00n's Avatar
Can you program the ecu to not throw a cel when the cat has been removed? Sorry for the really simple question.
Old Jul 6, 2010 | 07:24 PM
  #624
Golden's Avatar
Yes. You need EcuFlash and a Tactrix cable. Check the DTC thread. (You may want to search within that thread, as it is a bit long)
Old Jul 29, 2010 | 05:02 PM
  #625
Kasander's Avatar
I know it's not the RA section but I figured it might be better to ask it here.
In the process of installing a 3 ports on a friend RA 09, I noticed that my definition for 53600009 are missing the Reactive WGDC correction interval high and low gear. I'm also missing the WGDC Max total upward correction vs tps.
If someone got those table that would be greatly appreciated
Old Jul 29, 2010 | 05:15 PM
  #626
GST Motorsports's Avatar
54696
5346a
58d12 and 6265a (TPS)
In order of your requests.
- Bryan
Old Jul 30, 2010 | 05:00 AM
  #627
Kasander's Avatar
Thank you very much Bryan, that will make my setup a bit easier
Old Nov 15, 2010 | 02:23 PM
  #628
RazorLab's Avatar
I'm going to try and update this thread pretty soon... Sorry for the lag guys
- Bryan
Old Feb 14, 2012 | 05:24 PM
  #629
evoxmr1989's Avatar
So i just gotta connect the ECU via USB to the computer and it should read the ecu or is there another way i gotta hook it up for the program to read it ? another thing because i know nothing I'm in my 1st month in Lincoln Tech learning a few things but can I rewrite my ECU with stock everything or do i need to make an upgrade first ? thanks in advance
Old Jul 18, 2012 | 08:00 PM
  #630
KeepCreepin's Avatar
The more power you want the more aftermarket accesories you need to put on as far as mechanical parts go. From my experience tuning WRXs (correct me if I'm wrong) you read your ROM with ecuflash and save that ROM to your computer, then you use your tuning software, whichever one you choose, to open that file and you make your adjustments. Then from the tuning software you save the new ROM and open that same ROM in ECUFlash to write to the ECU in your car.
