Resetting Trims and effects
Old Nov 29, 2008 | 10:17 PM
PeteyTurbo's Avatar
if your ltft low is negative you want to decrease latency fyi, and if your ltft mid is negative you want a higher number in the scaling
Old Nov 29, 2008 | 10:31 PM
bchappy's Avatar
once again thank you guys alot for your input. Hopefully i can get this stuff sorted out. I think i am getting a handle on understanding the trims and adjusting them.
I over complicate everything, and usually get these numbers mixed up when a bunch of info is coming in.
Thank you.
Old Nov 30, 2008 | 01:27 PM
bchappy's Avatar
alright I just dont get WTF is going on it is still pig rich and have went through many many settings.
I am really wondering why it would run perfect up until I reset the ECU now it wont take any boost.
anything more than 40% throttle and 4psi and the car dumps fuel (9.0afr) and then has a fit like hitting a fuel cut which is as said before probably the spark blowing out.
any ideas anyone?
Old Nov 30, 2008 | 03:05 PM
tnt1106's Avatar
maf plugged in? double check all settings in rom then reflash. even if settings are fine reflash
Old Nov 30, 2008 | 03:25 PM
bchappy's Avatar
ya the maf is plugged in, I am going to start off fresh with a ROM and see if I can clear up the issues.
Old Nov 30, 2008 | 09:08 PM
mrfred's Avatar
Resetting the trims wouldn't cause the open loop AFRs to change. Before you start doing WOT runs, get the trims as close to zero as possible. For this time of year, the only places dispensing 85% ethanol are west coast cities and a few select filling stations that keep the same mix year-round. My guess is that you'll have to have a higher scaling than what I use for E85.
Do some more stop and go driving to stabilize the trims. You'll have to iterate between tweaking latency and tweaking scaling. As someone said, LTFT Low is mainly dependent on latency. LTFT Mid depends more evenly on both.
Once you get the trims nailed down, then start checking the WOT AFRs.
Old Nov 30, 2008 | 10:04 PM
bchappy's Avatar
Thank you for chiming in everyone, I will dedicate a full day and get nailing down the trims, I was a little confused but I understand the mechanics of the trims and such now.
Old Dec 1, 2008 | 12:04 AM
GotWheelHop's Avatar
Brandon, if you can't get them squared away this week, we can go do some logging and such on Thursday and try and get you on the ball.
Old Dec 1, 2008 | 01:19 PM
bchappy's Avatar
Thanks Eddie I should be able to track them down have fun with the stocker again, it felt real strong!
awdordie
17
Feb 26, 2017 09:16 PM
UF_Evo
Jan 19, 2017 01:55 AM
Raceghost
Dec 15, 2016 02:54 PM
Crester
May 26, 2011 05:51 AM
voidhawk
Nov 10, 2007 06:04 PM
