Help/Advice Please
Old Dec 26, 2008 | 05:19 PM
rolly1818's Avatar
Registered User
Post Help/Advice Please
today i decided to pull 2 logs since i changed the boost settings in the car.
i am currently running wastegate boost ~14/15 psi.
i am currently running the STOCK Maps
after pulling the logs today i am getting a max of 18 counts of knock for some reason even though i am running reduced boost.
in addition for some reason my car is saying i am getting 30 psi!!!
i would really like to start tuning my car (JDM Evo IX - car is bone stock). i have attached the logs for some help/advice!
Thanks in advance.
File Type: zip
Old Dec 27, 2008 | 01:02 AM
rolly1818's Avatar
Registered User
bump for help
Old Dec 27, 2008 | 02:15 AM
burgers22's Avatar
Yes there are some strange things going on there. The timing is very high for peak boost, but maybe not if you're running wastegate pressure
Here's a few questions.
How are you measuring boost?
Do you have the wideband logs?
Do you have an induction kit?
Can you post your fuel and timing maps?
Can you post a photo of how you have your boost pipes conected?
You'll also notice that the octane number isn't being decremented and the IDCs look very high for wastegate boost and shouldn't you be logging JDM map to get the boost direct from the ECU?
MB
Old Dec 27, 2008 | 10:45 AM
rolly1818's Avatar
Registered User
1. MAP Sensor comes with the JDM Evo IX
2. no WB logs, i am just testing the car right now. WB will be bought soon.
NOTE: i have not changed the stock maps at all!
3. induction kit? nope
4. i will need email addys to send maps..
5. boost pipes are stock piping the car is bone stock!
Old Dec 27, 2008 | 03:20 PM
burgers22's Avatar
Just do a screen shot opf the maps. Note the thing I asked about logging JDM MAP for boost.
MB
Old Dec 27, 2008 | 05:09 PM
rolly1818's Avatar
Registered User
i will post up soon, BTW they are the stock JDM GSR Maps so u should have them!
Old Dec 28, 2008 | 04:09 AM
C6C6CH3vo's Avatar
What is the PSI your "car is saying" at idle and cruise? If it's showing correctly (i.e. vacuum or < 0 PSI) and boost readings are good the WGA may not be getting control air for some reason
Old Dec 29, 2008 | 03:39 AM
rolly1818's Avatar
Registered User
just read on Evoscan u need to subtract 15 psi.... so i guess i am fine.
still slighlt confused about the timing and knock i am getting!
DsmEvo87
20
Aug 18, 2015 08:14 AM
Evilami
Nov 17, 2013 10:59 PM
chucksss
Sep 4, 2012 11:47 AM
vortico
Dec 10, 2011 02:55 PM
sal03evo
Apr 27, 2010 10:32 PM
