ECU Swap & Immobiliser Code Issues
Old Jan 7, 2009 | 06:38 PM
rolly1818's Avatar
Registered User
no 899880002 is the correct romid for a GT
i read that off my GSR??? now i am confused again
my car is a JDM 2006 Evo IX GSR, mellon told me i should be using a more popular rom --> 88580014.
will this cause any problems?? wouldn't i miss stuff because it is not a JDM Map?
Old Jan 7, 2009 | 06:43 PM
tephra's Avatar
88580014 doesn't have dual BCS or MAP.
you will be able to log MAP with 88580014 thou..
Old Jan 7, 2009 | 06:46 PM
rolly1818's Avatar
Registered User
i am in the process of running a 3 port boost solenoid so no dual BCS again..
the MAP maybe an issue. FYI i am a novice.
Old Jan 7, 2009 | 06:47 PM
tephra's Avatar
i actually prefer 88580014 (as its my rom)
does your GT have a rear 02 sensor?
i think it doesn't - in which case 88580014 will CEL
Old Jan 7, 2009 | 06:54 PM
rolly1818's Avatar
Registered User
so use what mellon is saying?
not sure about the O2 sensor....damn i am trying to understand tuning my car and it feels like am getting into a very deep hole here!
Old Jan 7, 2009 | 07:01 PM
tephra's Avatar
just find out if you have a rear 02 sensor.
if you DO - then swap to 88580014 is ok
if NOT then you need to stay on your ROMID (until we can come up with a FULL rear 02 disable)
Old Jan 7, 2009 | 07:03 PM
rolly1818's Avatar
Registered User
i am guessing its as easy as looking under the car.
BTW i have a TBE that will be installed on Friday night!
Old Jan 7, 2009 | 07:13 PM
tephra's Avatar
yeah - if you see a sensor coming out of the top of the flange of the main cat then its got a rear02
Old Jan 7, 2009 | 07:17 PM
rolly1818's Avatar
Registered User
highly doubt it.....never saw anything like that...
if it does what do i do?
so 88580014 will work with my car even though it is JDM?
its a stock map right? i will just need to reconfigure for the initial 3 port BS and then adjust from there, etc.
Old Jan 7, 2009 | 09:57 PM
tephra's Avatar
personally I don't like changing ROMID families, but sometimes it is necessary.
just keep a backup of your stock ROM and then try flashing the new one in.
you will know soon enough if it doesn't start/throws CELs
you *may* have to disable the immobiliser (at least initially, try the immobiliser fix we found)
Old Jan 8, 2009 | 02:42 AM
rolly1818's Avatar
Registered User
cool thanks for all your help thus far!
if i need to change the immo code i know how to thanks to RoadSpike.
i will give you guys an update this afternoon, i am in work right now!
Old Jan 8, 2009 | 04:08 AM
rolly1818's Avatar
Registered User
cool so i am setting up my Ecu Flash to run rom - 88580014.
quick one:
i need to delete the old xml file i have and replace with the new one containing Tepra;s V5.10 mods so i can run it?
am i getting this right?
i am gonna delete the old xml, change the name on the new one to 88580014.xml and put it in the folder then i should be fine?
Old Jan 8, 2009 | 04:56 AM
tephra's Avatar
no u need to copy/paste the XML FROM the mod.txt INTO the 88580014.xml (before the </rom> at the end)
Old Jan 8, 2009 | 04:59 AM
rolly1818's Avatar
Registered User
Thanks again.
do i need to remove all the previos data from the old rom first or just copy and paste?
i owe u some
Old Jan 8, 2009 | 05:02 AM
tephra's Avatar
only remove any old tephra mod xml (by the sounds of it you wont have any anyways)
