ECU Swap & Immobiliser Code Issues
Old Dec 16, 2009 | 02:51 PM
  #61
VGergo's Avatar
Originally Posted by RoadSpike
Patching the ECU is easy just need a way to connect it with a laptop. There are many MANY threads out there with that information just search them. Event this thread has the codes needed to disable the immobilizer in the 1st page or so.
Just editing the rom xml file the value to 56D2 and will work the evo ecu ? that is easy thank you ! If I would put back the stock outlander ecu than evertyhing will be the same will use again the immobilisier ?
Old Dec 16, 2009 | 02:54 PM
  #62
VGergo's Avatar
The harness will be the most difficult part of the build i'm sure.
The second will be figuring out how to get the data port connected so you can even flash the ecu. I'm not sure what pins the laptop connects to.
Ohh I see. data port is near the obd connector where the white small connector in the tactrix cable plug in ?
Old Dec 16, 2009 | 02:57 PM
  #63
RoadSpike's Avatar
Yep that white connector is key to flashing the ECU apparently.
And no you don't edit the XML to flash the ecu the XML is merely there so you can see the place to change in the ECU. You have to open EcuFlash and download your rom first then edit the appropriate spot.
Periphery0 (FAA) to that value.
Old Dec 16, 2009 | 03:02 PM
  #64
VGergo's Avatar
Okay I know which pins need in the outlander to flash the ecu
If i coud download the rom than I change it to the European one which doesnt use the MDP ?
anyway thank your help I have to build my harness !
Old Dec 16, 2009 | 03:06 PM
  #65
RoadSpike's Avatar
Yeah you may as well use tephra's v7 rom without speed density patch for this since its a EDM rom without map sensor. Plus it has many neat tricks in it to help the car fly.
Old Dec 16, 2009 | 03:12 PM
  #66
VGergo's Avatar
great tephra v7 without speed density working from the MAF only ?
It will be fly !!!
Old Mar 14, 2018 | 03:40 AM
  #67
Wajeb G. Wahab's Avatar
You know how to edit your rom.xml file to add a table?
<table name="(periphery 0)" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
Stock should be 56DA
Change to 56D2
So if my periphery 0 says 56D8 on the new ROM that I'm trying to flash on my car, I should enter that into the code?
<table name="56D8" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
Is that correct?
YaroRS
Feb 10, 2012 04:54 AM
YaroRS
May 14, 2011 12:20 AM
acsian
Dec 8, 2009 07:13 PM
jimmy79
May 19, 2008 04:33 AM
R. Mutt
Feb 6, 2008 11:08 PM
