Disabling EGR and fuel pressure solenoids
Old Jun 29, 2011 | 09:48 PM
  #316
badev0's Avatar
Originally Posted by tscompusa
0 disables it not 1.
It was 0 by default when the light came on.
Old Jun 29, 2011 | 09:51 PM
  #317
tscompusa2's Avatar
it was zero cause thats what David set it to then. default its 1 (on)
Make sure everything's done that EvoRyder said.
Old Jun 30, 2011 | 01:54 AM
  #318
Evoryder's Avatar
Didn't even realize. You have the routine enabled, as advised 0 turns them off. The only bit that is not 0 for disable is FAA bit 11, that requires a 1 to disable.
Here is a spread sheet with all the enabled routines:
https://www.evolutionm.net/forums/at...t_20080830.pdf
Old Jul 3, 2011 | 03:43 PM
  #319
R0b's Avatar
R0b
are you sure its 1 to disable? every other post here on this thread says its 0 to disable?
Old Jul 3, 2011 | 04:12 PM
  #320
merlin.oz's Avatar
That spread-sheet shows FBA bit 7 as Lean-Spool.
It should be FBA bit 0.
Old Aug 1, 2011 | 01:32 AM
  #321
GregM's Avatar
I just disabled FCA bit 15, but still get a P0403 error.
Old Aug 1, 2011 | 06:30 PM
  #322
Evoryder's Avatar
FCA BIT 15 is for evap. Periphery 2 FCA bit 9 disables EGR. Below is a quick reference i made awhile ago.
NOTE: When removing the entire solenoids and hoses disable the following periphery bits.
Periphery 0/FAA:
-EGR(ign advance) Bit 11 disable(some people leave it on, up to you)
Periphery 2/FCA:
- EVAP> Bit 13,14,15 Disable
- EGR > Bit 9 Disable
Periphery 4/FEA:
- FPR> Bit 7 Disable(When you also disable FCA/P2 Bit 15 that will also take care of the FPR)
__________________
Old Aug 1, 2011 | 07:19 PM
  #323
GregM's Avatar
I disabled FCA bit 9 as well, but what I have seen links P0403 to bit 15. It sounds like the Periphery bits for my car may not match the Evo.
Old Aug 1, 2011 | 08:41 PM
  #324
Evoryder's Avatar
oh. You have a evo 7...
Old Aug 1, 2011 | 08:46 PM
  #325
GregM's Avatar
Nope, its an Airtrek, basically an Evo7 engine with an auto.
Old Aug 1, 2011 | 09:03 PM
  #326
Evoryder's Avatar
You're going to have to check with the ecu guru's.
Old Aug 1, 2011 | 09:11 PM
  #327
GregM's Avatar
Yea, MrFred found the EGR disable for me, hopefully he can figure this out for me as well. We are lucky there are guys out there that can do this stuff, its way over my head.
Old Aug 1, 2011 | 09:19 PM
  #328
Evoryder's Avatar
yeah Tephra, Acamus, Mrfred etc... allows us to put this car on another level.
Old Sep 5, 2011 | 01:30 PM
  #329
LV///R's Avatar
Periphery 0/FAA:
Periphery 2/FCA:
Periphery 4/FEA:
So to clarify. If I've removed only my EGR valve/hoses and my FPR Solenoid, I only have to change:
FAA Bit 11 disable (EGR)
And
FEA Bit 7 disable (FPR)
I don't have to touch FCA bit 15, correct?
Thanks!
Old Sep 7, 2011 | 11:00 PM
  #330
Evoryder's Avatar
correct
