need Evo 9 owner to test rear O2 *heater* sim patch
Old Feb 16, 2009 | 09:25 PM
  #76
fostytou's Avatar
EvoM Community Team
Originally Posted by vmrevo9
well removing the rear o2 sensor completely from the car be necessary when one has the 2 antifoulers installed with the sensor? resaon i ask is so just in case i need to bring it in for warranty work i can return it easily to stock
Can you rephrase the question? It doesn't really make sense...
Old Feb 17, 2009 | 05:16 AM
  #77
vmrevo9's Avatar
Veteran: Air Force
sorry about that havent been to bed yet.
what i meant was is it necessary to remove the rear o2 sensor after the sim patch as been installed and the sensor is no longer in use? i have 2 antifoulers on the o2 sensor right now. i would like to leave the o2 sensor where it is so that i can repin the ECU and retune the rom back to stock if need be.
Old Feb 17, 2009 | 05:54 AM
  #78
MR Turco's Avatar
You could damage the sensor by turning it off but keeping it exposed to the exhaust gases. I believe mrfred said this happens rather quickly too. I am not sure how much less heat it will be exposed to by running two antifoulers though.
Old Feb 17, 2009 | 06:32 AM
  #79
rose0529's Avatar
S2Kracka and Scheides put this on my car on sunday and it works great! Thanks!
Old Feb 17, 2009 | 06:47 AM
  #80
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Originally Posted by mrfred
Glad there's no CEL. When you get a chance, can you check the readiness status of all the OBD-II tests? Just want to be sure that everything has completed.
I have had a look at the patch, it seem to me it does more than needed (both heaters, front and rear) Was it intention or am I missing something?
Code:
00047E4A                 mov     #2, r4
00047E4C                 mov     #0, r5
00047E4E                 mov     #1, r6
00047E56                 mov     #1, r4
00047E58                 mov     #0, r5
00047E5A                 mov     #1, r6
Old Feb 17, 2009 | 07:39 AM
  #81
mrfred's Avatar
They're both rear O2 related. One resets the high current code, and the other resets the low current/high voltage code.
Front O2 would be r4 = 0x200, 100, r5 = 0.
Old Feb 17, 2009 | 08:14 AM
  #82
travman's Avatar
I setup a friend with this patch last night - he reported the cel was gone, I will get him to check the ready monitor to see if it completed.
Old Feb 17, 2009 | 08:33 AM
  #83
acamus's Avatar
thank you for the clarification.
Old Feb 17, 2009 | 09:21 AM
  #84
mrfred's Avatar
Old Feb 17, 2009 | 09:56 AM
  #85
recompile's Avatar
I passed Massachusetts inspection today with this patch applied.
Previously, I had failed inspection with the Tephra v5.1, O2 Simulator on, and resistor mod with rear O2 removed. I believe the resistor was faulty because I was throwing P0037, which I am no longer throwing with this patch.
The only change was adding this heater sim code to the existing Tephra v5.1 ROM.
Also worth noting is that the O2 Readiness test failed in both cases (although I still passed inspection even though it reported "Not Ready"). This may be a deficiency in Tephra's O2 simulator, because the front O2 sensor is brand new. The FAA ECU Periphery is stock as well.
Thanks mrfred, Tephra, and others
Old Feb 17, 2009 | 11:55 AM
  #86
fostytou's Avatar
EvoM Community Team
If you had recently flashed it may have reported not ready rather than failed. Did you drive for an hour or so before heading to the emissions station?
Amazing you still passed, they wouldn't let that fly in IL.
Old Feb 17, 2009 | 02:27 PM
  #87
recompile's Avatar
I drove it for 2 days before heading to the inspection station.
Old Feb 18, 2009 | 07:00 AM
  #88
acamus's Avatar
Originally Posted by recompile
..... both cases (although I still passed inspection even though it reported "Not Ready").
mrfred, if I understand this right, there are four possible states for r5
0x0 - not ready as stated above,
0x1 - failed?
0xC - ?
0xD - ?
what about testing them which one is "PASSED"?
Old Feb 18, 2009 | 07:52 AM
  #89
mrfred's Avatar
Combinations of r4 and r5 are used to indicate which OBD-II test is being reset. OBD-II code vs r4 and r5 are indicated in the OBD-II code table xml for Evo 9s. Take a look at the latest ECUFlash Evo 9 xmls.
Old Feb 18, 2009 | 09:37 AM
  #90
acamus's Avatar
I am speaking of sub 32946 in 88590015
Code:
00032956                 mov     r5, r2          ; r5' -> r2
00032958                 mov     r4, r1          ; r4' -> r1
0003295A                 mov     #0, r0
0003295C                 mov.w   r0, @(8,r14)
0003295E                 mov     #0, r9
00032960                 mov.w   r0, @(h'C,r14)
00032962                 extu.w  r2, r2
00032964                 extu.w  r2, r10
00032966                 tst     r10, r10
00032968                 bt      32980
0003296A                 mov     r2, r0
0003296C                 cmp/eq  #1, r0
0003296E                 bt      32980
00032970                 mov     r2, r0
00032972                 cmp/eq  #h'C, r0
00032974                 bt      32980
00032976                 mov     r2, r0
00032978                 cmp/eq  #h'D, r0
0003297A                 bt      32980
