TephraMOD V6 - testing!
Old May 22, 2009 | 02:12 AM
  #811
tephra's Avatar
thanks John!
Old May 22, 2009 | 06:19 AM
  #812
phenem's Avatar
What does the twin solenoid setup do anyway?
Old May 22, 2009 | 12:02 PM
  #813
scheides's Avatar
EvoM Moderator
Tephra,
I seem to have direct boost mod working properly on pump gas, still testing out other features, but one that is not working for me is alt maps. I logged Mut83 and get numbers in the 210-220 range, which is normal. I have my trip-point set at 3.01v (stock) and I have the ModOption for Alt Maps set to 1 (ACD0F). I have not tested for timing or AFR map changes, because the most obvious one to watch for me is WGDC and boost. It seems to just stay on my pump gas settings (base map).
Is there something I'm missing, or something I can check to see what is going on? If I load my v5 rom, it works as it always did.
Old May 22, 2009 | 12:34 PM
  #814
fostytou's Avatar
EvoM Community Team
Originally Posted by scheides
Tephra,
http://evoecu.logic.net/wiki/TephraM...Alt_Map_status
Did you actually change MUT83 or just log it?
Old May 22, 2009 | 01:00 PM
  #815
scheides's Avatar
EvoM Moderator
I just logged Mut83. I didn't change it to that value (although it could be already?). It showed 0 with my alky kit off, and 200+ with it flipped on. On my old rom, this switched me to the alt maps.
Does the link above do anything besides scale the 0-255 values into voltage? Does logging the Mut00 value actually verify that it is on the various base or alt maps?
Old May 22, 2009 | 01:10 PM
  #816
fostytou's Avatar
EvoM Community Team
Only if you change the MUT value to match. Verify that those two values match and I guess you will have your answer (Or alternatively put it at a different MUT location. I believe 00 is airflow 2 byte as included with the tephra roms).
Old May 22, 2009 | 03:18 PM
  #817
scheides's Avatar
EvoM Moderator
Ok, following the advice above changing Mut00 to 0x8425 and logging it, it stays at zero no matter what I do. I do see voltage change from 0 to 4.x volts, so I know that's working. If I change Mut83 to 0x6B0D kinda breaks both of those don't do anything when I toggle my alky on/off.
Comparing my mut table to the one included in the rom from tephra, I see the following are different. Any of these ring a bell on what might be causing my issue? I'm sure they've been change for various mods along the way, I have evoX map sensor, direct boost, and I'm sure a few other of the common mods done.
00 (as discussed above)
40
01
41
02
42
03
43
04
44
05
09
8A
8B
3C
83 (as discussed above)
Old May 22, 2009 | 08:31 PM
  #818
tephra's Avatar
send me your rom, i'll dbl check everything is ok...
hrmm has anyone else had problems with ADC0F altmap switching?
Old May 22, 2009 | 08:48 PM
  #819
scheides's Avatar
EvoM Moderator
Sent, along with a small token of my appreciation
Old May 23, 2009 | 08:07 AM
  #820
fostytou's Avatar
EvoM Community Team
This is as-set in my rom:
v6
00 - 8450 - was 2 byte load Now gm/S
01 - 8451 - was 2 byte load Now gm/S
02 - 6b7e - was 2 byte RPM now Airflow 2Byte
03 - 6b7f - was 2 byte RPM now Airflow 2Byte
04 - 6d85 - 2 byte airflow
05 - 6da7 - 2 byte airflow
3c - 8409 - Was ??? now Analog Wideband AFR / real rear O2 = MUT19 6a6f - same as MUT12?
--20090427 - should use MUT 12 and 19
19 - 8417 - JDM MAP - Non Averaged
--20090427 - should use MUT 3c
38 - 6AED - Log boost (averaged with tephramod)
40 - 8447 - Now Gear was JDM MAP non-averaged (original ROM= MIVEC?)
41 - 840b - load 1 byte
42 - 8448 - gear/mph
43 - 8449 - gear/mph
44 - 8443 - MAT
8a - 6EE3 - direct boost
8b - 6EE9 - direct boost
I was foolish and not tracking the changes I had made at the time, so I had to spend alot of time going back through and trying to figure out what things were.
On a similar topic... not understanding how the ECU works in this case. Are the MUT locations actually used internally for calculations in the ECU or are they only for output/logging. IE: If I changed MUT 40 to something other than RPM/Speed would it break that functionality?
Old May 23, 2009 | 06:03 PM
  #821
tephra's Avatar
just for logging
Old May 24, 2009 | 11:27 AM
  #822
scheides's Avatar
EvoM Moderator
tephra, did you get my rom? Any ideas?
Old May 24, 2009 | 11:28 AM
  #823
nothere's Avatar
nm
Old May 24, 2009 | 02:45 PM
  #824
tephra's Avatar
Chris - yup. I will check it out today!
Old May 24, 2009 | 07:18 PM
  #825
tephra's Avatar
Has anyone else had problems with ADC0F map switching?
What about ICS or TPS???
Chris - Can you give TPS switching a go?
I looked at the code and cant see anything immediately obvious
