Need help tuning the idle with kelford 272's
Old Mar 1, 2009 | 08:18 PM
  #31
Appauldd's Avatar
says invalid or corrupted for the Zip file
Old Mar 1, 2009 | 08:40 PM
  #32
Gordian79's Avatar
I had to add fuel at idle with BF 272s.i also upped the timing to 10 deg.now car idles great after i let it idle for awhile.i guess ecu learned idle again.heres a clip http://www.youtube.com/watch?v=0WPWiHzzZGU
Old Mar 1, 2009 | 08:42 PM
  #33
fixem2's Avatar
Try the file again. I editted my post above
Old Mar 2, 2009 | 05:31 AM
  #34
b16a95eg's Avatar
yeah i was messing around with the values a little in the lower hz columns, not the actual hz themselves. but they say to add the 2 together to see what you should either +/- by that %. i was just wondering since my STFT is all over the place if i would just disregard it and judge off my LTFT low, which was at a constant -6.675 or something close to that
Old Mar 2, 2009 | 05:32 AM
  #35
b16a95eg's Avatar
i put them back to stock, since i wasnt sure about the STFT
Old Mar 2, 2009 | 10:02 PM
  #36
Appauldd's Avatar
The MAF scaling template is pretty neat. I had to adjust the calculations for EvoScan, but it works pretty well.
What is the status on your idle b16???
Old Mar 2, 2009 | 10:35 PM
  #37
b16a95eg's Avatar
i havent gotten a chance to put the stock rubber tube back on yet, i had school from 8 to 6 and then homework and food, then it was dark and cold, haha, so hopefully tomorrow, what did you change in evoscan to get it to read properly? i only changed the scaling so it would read hz in ecuflash
Old Mar 2, 2009 | 10:37 PM
  #38
b16a95eg's Avatar
but what should i do about that STFT? just never mind it or what? and i did a log and my LTFT low was still the same, even after i put the settings back to stock, i thought that would've changed since it did when i changed it. but it didnt, just stayed the same
Old Mar 2, 2009 | 10:41 PM
  #39
Appauldd's Avatar
Since you have an VIII, like me, you will need to disconnect the battery and try to start the car to remove any residual memory. Then re-connect the battery and start the car. Let it idle for at least 16 minutes to get 4 cycles through it. You should see your LTFT low make an adjustment.
The EvoScan calculation is supposed to be....0.1953125*x-25 for LTFT low, mid and high.
Old Mar 3, 2009 | 05:35 AM
  #40
b16a95eg's Avatar
ok thanks, i'll give that a try here today, oh and mine is white too :P
Old Mar 3, 2009 | 04:17 PM
  #41
b16a95eg's Avatar
well, more problems, i have a horrible vibration above 4500, it feels like i'm driving over constant rumble strips..... only without the little pauses, its just constant, so now i have to figure out where this is coming from...
Old Mar 3, 2009 | 06:49 PM
  #42
Appauldd's Avatar
If you are losing power too....I say check your plugs. Your fuel condition may have fouled the plugs.
Old Mar 4, 2009 | 07:13 AM
  #43
b16a95eg's Avatar
i think that vibration was coming from the balance shaft probably being off for timing, i checked on all data and it didnt look like how they said it should, they had the little dot on the oil pump at about the 11 o'clock postion, mine was at the like 2 or 3 if my friend remembers right (he was down at the bottom) but he said thats the way it came off, but i dont think it was because i never had that problem before. So i'm going to try and fix that today, if i can get in the schools shop
Old Mar 4, 2009 | 08:37 AM
  #44
b16a95eg's Avatar
this is how all-data says to have it, but my crank key was facing the 3 o'clock when it was at tdc, so i'm not sure, and my oil pump pulley was also facing 3ish
Old Mar 4, 2009 | 08:41 AM
  #45
Appauldd's Avatar
You may need to turn the engine over a few full rotations to get everything to line up.
stunt2
Jul 18, 2014 08:05 AM
mshilto89
13
Feb 9, 2013 04:21 AM
Tmosser
Sep 20, 2012 01:46 PM
awdordie
Mar 10, 2011 10:14 AM
EvoDom
12
Nov 19, 2008 04:03 PM
