how much timing do you run?
Old Mar 20, 2009 | 06:38 AM
FastAzzEvo's Avatar
I have an 850R, but I trying to get some opinions on timing.. I was doing some loggin and noticed through 4th gear I'm starting around 7 degrees and ending up at 10degrees and was thinking that was really low timing.
of course big turbo applications would be most helpful and pump gas 93...
thanks.
Old Mar 20, 2009 | 06:58 AM
Boltz.'s Avatar
FCOTM Winner
IX's don't need as much timing as VIII's because they are more efficient. Everyones setup is also different, who tuned your car?
Old Mar 20, 2009 | 07:06 AM
Chabada15's Avatar
7 at peak torque going to 15 at redline
Old Mar 20, 2009 | 01:03 PM
cij911's Avatar
In my peak tq areas I am ~4* going to ~16* @ redline (28psi tapering to 22psi on a 9 turbo running 91 + Meth/Water mix)....
Old Mar 20, 2009 | 02:01 PM
lan_evo_mr9's Avatar
4/5 peak torque going to 14/15 redline.
Old Mar 20, 2009 | 08:43 PM
C6C6CH3vo's Avatar
With peak pressure as close as possible to where best torque is.
Old Mar 20, 2009 | 08:52 PM
Mellon Racing's Avatar
comparing timing values is pointless unless the other cars are running the same mods/boost/octane
a stock turbo car at 20psi can run 20*+ but a 35R at 30psi making double the hp won't run near that much.
Old Mar 20, 2009 | 09:30 PM
tephra's Avatar
yeah bit of a pointless thread...
never TRY and run the same timing as other ppl... just tune your own car in little steps and u'll be right!
Old Mar 21, 2009 | 08:16 AM
THUB's Avatar
Does anyone have any theories as to why some cars can run/ need more timing to make power? It seems like my car runs a few degrees more timing than anybody else around. I've never really worried about it because the fueling is right and it's making good, knock-free power. I was just curious.
Old Mar 21, 2009 | 08:59 AM
03whitegsr's Avatar
Could merely be the accuracy of the ignition system trigger plate/pickup location.
Could be carbon deposits.
Could be minor setup differences that actually have a big impact on cylinder filling/air distribution.
Could be injector balance.
Going off a knock sensor and not doing individual cylinder tuning means that you tune to the weakest cylinder. If something in the setup for some reason makes one cylinder prone to detonation, you limit the power of the motor to what only the weakest cylinder can make. Keep everything well balanced where every cylinder is at optimum performance though and it can make a huge difference in how aggressive you can run the tune and how much power you can make.
Old Mar 21, 2009 | 04:19 PM
tephra's Avatar
i reckon its base timing off...
Old Mar 21, 2009 | 08:11 PM
WRC-LVR's Avatar
Yeah That's a good thought ^^ and keys with every car is a little different, at reading the CAS etc
My VII just doesnt like much timing but I dont stress over it. If anyone asks I usually tell them to tune it for what the car likes. Just takes iterations and time.
Milburn
Old Mar 21, 2009 | 08:17 PM
C6C6CH3vo's Avatar
AFR is probably the main reason
sslevo
E85 / Ethanol
Aug 30, 2011 10:25 AM
Jp7
Jul 29, 2010 07:38 PM
chriseacrett
Apr 17, 2008 11:21 AM
Tek3Evo
Jan 12, 2008 09:35 PM
fuzzychi
Aug 16, 2005 04:41 PM
