91 oct at 5000 ft. what do you think?
Old Apr 11, 2009 | 10:31 PM
EVOIXreno's Avatar
what do you think...did some tuning tonight....25-26 psi
11.4-11.5 afr's
Cory
File Type: doc
Old Apr 11, 2009 | 10:37 PM
Silver05Bullet's Avatar
its pretty good the only thing where it hits the 3 counts of knock i would maybe pull some timing but even with the 3 counts you should be fine
Old Apr 11, 2009 | 10:38 PM
EVOIXreno's Avatar
It went a little lean so I richened up a little....so 1-2 counts now... but I didn't think I could run this much timing!
Old Apr 12, 2009 | 09:59 AM
EVOIXreno's Avatar
up top!
Old Apr 12, 2009 | 02:40 PM
WRC-LVR's Avatar
That is a lot of timing. Could be the 5000 ft, was the WB calibrated at that elevation? If you are running the JDMMAP is that properly cal'd for that elevation?
Nice results and good job of adjusting it after.....I cant run 26 psi boost here in Atlanta on 93, but it is only a VIII MR / 10.5 hotside, not a green so it gets a lot hotter.
Milburn
Old Apr 13, 2009 | 01:00 PM
kilawind's Avatar
what gear did you do the pull in?
Old Apr 13, 2009 | 01:11 PM
EVOIXreno's Avatar
3rd
Old Apr 13, 2009 | 01:13 PM
kilawind's Avatar
go do a 4th and make final adjustments.
Old Apr 13, 2009 | 01:23 PM
EVOIXreno's Avatar
Funny you say that... I just did on my lunch...I turned the boost down to 25 even and had to take out 1 degree up top... I will post a log later for you. What do you think Allan?
theblackbeast11
32
Mar 21, 2013 12:34 PM
rrkpitt15
12
Sep 11, 2011 06:59 AM
EVO8_GSR
Jan 20, 2011 04:07 PM
Crester
26
Jun 19, 2010 12:13 AM
11secEVO7
Jan 16, 2005 04:10 PM
