Need spare 0-5v logging input???
Old May 3, 2009 | 04:47 AM
  #31
kkarim's Avatar
Originally Posted by mrfred
What I wrote about 10 bit resolution is only for ADC 0C. Do you want it for the MAP sensor ADC input?
yeah, i would really appreciate it if you could.
Originally Posted by tephra
a 4 bar sensor with only 2.5v of range???
for some reason, i only have this range on my map sensor, i suspected something was wrong with it or with my calibration at first, but these settings are spot on, although lacking a lot of resolution.
i am giving it a +5v reference and a clean ground, i suspected for a moment it might need +12v reference, but for some reason, i don't want to try and burn the sensor.
if nothing else works, i'll end up ordering an omni 4-bar map....
Old May 3, 2009 | 05:14 AM
  #32
tephra's Avatar
well i would find the spec sheet and confirm the numbers are correct.
if the sensor is buggered (OR you using the wrong PIN on the ECU) then now is the time to fix it
dudical26
Jan 10, 2020 08:21 AM
Mad_SB
14
Oct 4, 2017 04:08 AM
stokEd
51
Oct 14, 2015 06:44 PM
3VOLUTIONIST
May 18, 2015 10:02 AM
mrfred
Feb 24, 2015 08:42 AM
