NLTS patch is awesome!
Old May 6, 2009 | 06:31 PM
sslevo's Avatar
So idk if it was me or just my stock clutch and transmission but my 1-2 shift always sucked. Either i would grind 2nd a bit or i would have to shift slow and loose a lot of boost. Not a good situation for drag racing. With Tephra's NLTS patch i can shift easily with no gind or problems while holding a lot of boost. I can imagine this is not easy on the clutch so don't do it on every shift, haha. I am just excited i can finally shift, LOL. I think i will be making a donation after my next paycheck
Old May 6, 2009 | 11:06 PM
tephra's Avatar
cool thanks
what settings are you using? (for the benefit of others)
Old May 7, 2009 | 04:16 AM
rolly1818's Avatar
Registered User
cool thanks
Tephra people keep saying that NLTS damages the drivetrain? any info on this? would love to use it
Old May 7, 2009 | 04:33 AM
lost spyder's Avatar
NLTS when properly set-up and utilized is actually easier on your drivetrain than your standard short shift.
Old May 7, 2009 | 07:21 AM
sslevo's Avatar
I think it is probably easier on your transmission since it cuts the power while you are shifting, but i think its hard on the clutch since you hit the next gear at full boost. I have them on the default settings for now, 800 rpm drop, 98 %tps, 150 load. I will play with them a little bit latter, i just wanted to get the alt map switching setup for my E85 tune today
Old May 7, 2009 | 11:06 AM
rolly1818's Avatar
Registered User
intersting point i am on the stock clutch
Old May 7, 2009 | 03:11 PM
wtf_is_a_evo's Avatar
Ya i am interested in what settings you are running like rpm drop load and tps?
also what rpm do you shift at?
Old May 18, 2009 | 08:09 AM
20gmr's Avatar
My car loves No lift!!! shifts smoother no lifting then trying the *correct way*
scheides
Mar 1, 2014 09:45 AM
tephra
Jul 16, 2011 04:25 PM
evane
Jan 12, 2009 12:36 PM
evane
Jan 9, 2009 10:06 AM
TouringBubble
Oct 15, 2007 04:05 PM
