USB to Serial Adapters That Work
Old Jun 25, 2009 | 11:56 AM
  #46
Mellon Racing's Avatar
Originally Posted by gfng
Chris were u able to get drivers for vista???
i have gone thru 3 cables , and 1 girlfriend already cause it links to evoscan i can see afr s for 8 seconds then it freezes everytime
either i need a driver , a new cable , a new evo , or a new girlfriend
so you're telling us all it takes is a cable to get rid of a whiny girlfriend *writes this down just in case*
nah man, we gave up after reading 10 terrible reviews of the cable and used my dynex...viola!
Old Jun 26, 2009 | 02:26 PM
  #47
Asmodeus6's Avatar
I've always run the keyspan.
It works with everything I have ever used it for. I've even run it over.
Old Jun 27, 2009 | 04:43 PM
  #48
Gary@MellonRacing's Avatar
ive used now 5 cables an still it reads then freezes , my last one was dynex , im using vista , anyone know why this is happening ????
Old Jun 28, 2009 | 07:00 PM
  #49
Import Junky's Avatar
I ended up buying the GIGA WARE cable from Radioshack. Installed the driver, hooked up to the LC-1, plugged into the USB port and baM!!! Works like a charm. Some of you mentioned Belkin. I don't know if I have the driver for that still but I'm going to have to look around. I bought mine from staples last year and didn't have any luck with it. Although I don't remember installing the driver then. I'm sure I did though.
Old Jun 29, 2009 | 09:13 AM
  #50
mrcox's Avatar
Originally Posted by evo7girl
i connected the usb to serial cable , and i looged it thru evoscan
i am able to see , the wideband action only for 8 seconds , and then it stays at the last reading stuck ..
why is this happening ????
This question still hasn't been answered and I'm having the same problem. I'm also using Vista. Anyone have a solution?
Old Jun 29, 2009 | 08:23 PM
  #51
laramie_05MR's Avatar
I have tried the gigaware from Radio shack and just bought this one.
Originally Posted by recompile
I am wondering if I have a problem with the WB itself. I was able to log it(kinda) through Evoscan. The value was flickering. I can not however communicate with the WB directly. The WB did work at one point in time this year.
Old Jun 30, 2009 | 05:15 AM
  #52
at last im not the only one with this issue , can someone help US out on this
Old Jun 30, 2009 | 11:02 AM
  #53
Asmodeus6's Avatar
I hate to really say this, but - Buy the Keyspan Serial adapter and you guys will not be having problems.
It works on XP / Vista/ OSX and anything I have ever tried to connect to; from Innovate to Haltech. Evo scan, DSMlink, etc. Quit screwing around with random cables and get one that works! There was a post about cables not being shielded well. I would assume that is why it is timing out on you.
Old Jun 30, 2009 | 11:12 AM
  #54
I just udpdated the driver for the Belkin cable I bought last year and it worked for a couple of minutes and then the connection got lost. I reset everything and got the connection back without any failures.
Old Jul 1, 2009 | 01:58 AM
  #55
fostytou's Avatar
EvoM Community Team
Originally Posted by asmodeus6
i hate to really say this, but - buy the keyspan serial adapter and you guys will not be having problems.
It works on xp / vista/ osx and anything i have ever tried to connect to; from innovate to haltech. Evo scan, dsmlink, etc. Quit screwing around with random cables and get one that works! There was a post about cables not being shielded well. I would assume that is why it is timing out on you.
+1
Old Jul 1, 2009 | 01:13 PM
  #56
I will install the other LC-1 before I buy another cable. Then I guess I will buy the Keyspan.
Old Jul 1, 2009 | 02:29 PM
  #57
i orderd the keyspan cable , thanks
Old Jul 1, 2009 | 10:17 PM
  #58
linuxbatm's Avatar
Belkins work great in my experience. We use a ton of the f5u109s at work, you can normally pick them up on ebay for 10-15$
Old Jul 1, 2009 | 10:29 PM
  #59
Evoryder's Avatar
I went ahead and invested in this "keyspan" we'll see how it works
Old Jul 1, 2009 | 11:27 PM
  #60
Asmodeus6's Avatar
I wouldn't suggest it so strongly if it didn't work well. Actually I'm trying to think of times it didn't work. And I honestly think they were all hardware issues. Pins pulled out of harness connectors, bad socket job on an ecu. Things that nothing would have connected to.
Typically if the keyspan doesn't work, something's royally eff'd.
I've had this one for probably 4 years or so. In and out of a million cars. Never a problem. Connects every time, to every thing.
